Old 04-03-2011, 07:58 AM   #111
ochowdero
The spring is supposed to assist in returning the pedal but get the master and slave in place before you worry about it.
Yes, the stock spec for the pressure plate is correct.
okay thanks,
the pilot bushing is flush with the crank input on the engine.. whatever that spot is called..
and the flywheel is on...
i dont have money for a transmission jack..
can i use the floor jack to jack up my transmission?
if so how?
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 04-03-2011, 05:20 PM   #112
btwilson86
Super Moderator
btwilson86's Avatar
I've done that. Since it's not an automatic, you don't have to worry about crushing a pan or anything.
I've just balanced the transmission on the jack cup, kept a hand on it to stabilize it, and jacked it up.
I know that some places sell transmission jack adapters, they're supposed to go on a standard floor jack instead of the original cup
Old 04-03-2011, 09:17 PM   #113
ochowdero
i meant for the manual trans since its round and not a square pan..
i really want turbo
Old 04-03-2011, 10:26 PM   #114
Just use a 1' x 1' x 1/2" piece of plywood (NOT MDF or particle board!) and nail a couple scraps along two parallel sides as a guide leaving enough room to roll the tranny about 1/2" to either side. Then, use some metal strapping to attach it to the cup if there's not way to remove the cup and use a bolt through the board into the jack's head.
Old 04-03-2011, 10:36 PM   #115
ochowdero
haha quick and simple, i like it..
can i bolt up the starter after i install the transmission? or before?
i really want turbo
Old 04-04-2011, 01:27 AM   #116
Do it after. I can't remember for sure but I believe one if not both of the bolts run into or through the bell housing.
Old 04-04-2011, 04:39 AM   #117
ochowdero
my mechanic said after..
which makes sense cuz one of the brackets for the bellhousing is connect through the starter...
i got my clutch disk and my pressure plate on.. bolts on the PP and there alil less then hand tight..
ima torque em but before i do, is there anything i should be careful about? or do before i torque them?
(the alignment tool is still inside it BTW)
i really want turbo
Old 04-11-2011, 10:49 PM   #118
ochowdero
hey every9one...
i need to know how to bleed the clutch lines for the mk3 non turbo...
and i reallyy need a pcture of what the clutch pedal assembly looks like...
i feel something is wrong with mine.. so i need your help
i really want turbo
86.5 auto transmission removal HELP!!! elmer MKIII FAQ 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
