Old 03-14-2011, 05:38 AM   #81
ochowdero
hers the pics
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 03-25-2011, 06:52 AM   #82
ochowdero
Exclamation i didnt wanna make a new thread.
hey everyone.
im here to let you know im almost read to do the swap
im picking up my last parts tomorrow:
clutch fork
shifter
pedals
driveshaft
here is all the parts i have and need:
parts i already have:
w58
clutch master
slave cylinder
hard and soft lines
clutch kit
flywheel
flywheel bolts
clutch fork
drive shaft
shifter
and pedals
needed:
shift bushing
oil plug
if anything is missing please notify me, thanks :P
okay now on to my questions.
the pilot bushing?
where does it go? on the tsrm it shows a diagram of it going in between the flywheel and clutch disk.
but from talking to a mechanic and common sense, doesnt it go into the engine where the input shaft goes? then after that you put the flywheel, bolt it down and then the clutch assembly? am i mistaken? if so please correct me lol
the other question is what do i need to do EXACTLY to the neutral start switch?
thanks in advance
i really want turbo
Old 03-25-2011, 07:28 AM   #83
btwilson86
Super Moderator
btwilson86's Avatar
Pilot bushing goes into the small opening in the crankshaft flange (the part the flywheel bolts to). So it does sit slightly ahead of the flywheel, but it doesn't get in the way of any flywheel/clutch operations as it is smaller than the center hole in the flywheel.
Old 03-25-2011, 07:36 AM   #84
ochowdero
ahh that makes sense.
haha
what wires do i connect for the neutral start switch?
would i still need to push down the clutch to start the car?
i really want turbo
Old 03-25-2011, 07:39 AM   #85
btwilson86
Super Moderator
btwilson86's Avatar
Neutral start switch.... I'm not sure what you need to do to bypass that. Hopefully someone else on here can help you with that
Old 03-25-2011, 09:08 AM   #86
ochowdero
hey BT, the only thing missing on the transmission was the oil plugg right?
i really want turbo
Old 03-25-2011, 03:13 PM   #87
there is a sensor that looks like a 1/4 piece of pie, and the shifter for your automatic runs right through it.
remove it and plug it back in with it in the P ark position. or wire this into your new clutch pedal!
think you gotta wire in reverse lights also.
Old 03-25-2011, 03:18 PM   #88
http://www.celicasupra.com/forums/sh...ft-Bushing-Kit
you can buy the bushings for your w58 shifter and i think r154
mk2 and 3 both use the w58
i am still new to celicasupra.com but BillyM has been at the site since mar2003 or at least that is when the site got remade
he is reliable.
installation instructions:
http://forums.celicasupra.com/showth...868#post412868
Old 03-25-2011, 05:11 PM   #89
btwilson86
Super Moderator
btwilson86's Avatar
Yeah, that should be it
Old 03-26-2011, 09:40 AM   #90
ochowdero
okay i got it.
is there anyother drive shaft that i can take from another car that is a direct fit for the w58 trans/supra?
or can i use my auto one?
same thing for the shifter too
i really want turbo
86.5 auto transmission removal HELP!!! elmer MKIII FAQ 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
