Old 02-27-2011, 03:33 AM   #1
907mge
907mge's Avatar
Default 2JZ-GTE Swap
Well here it is the JDM 2jz my friend Trevor picked up from NJ this morning. It was $1700 for the motor,ecu, and auto tranny. The motor has a tag in japanese that says 92k Km, which I guess is the milage for it. Although this is the first step atleast the motor is here. It will probably be a good bit of time before it goes in. For now it will be going up on the stand to have the oil pan switched out.
And here is the mk3 that it will be going into.
The swap will probably end up taking a while since it will be a part time project, but I will try to document it as it progresses though.
Old 02-27-2011, 03:54 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
Subscribed....... Look forward to seeing it! If ya need help with the wiring let me kno. I did a 1j swap and have some good notes from it!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
all their is to know for a 7mgte swap mkiii<3 MKIII Supra 0 10-03-2010 10:23 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
