Bone Stock w Upgrades ;-)
Does anyone know the purpose of the square flat black box near the diagnostic block on a '87 7MGTE? It has a 4 wire plug going into it. It does not appear in the factory service nanual.
Got pics? Or even a part number? Doesn't sound like a sock component to me.
Here is a photo of another Supra. I has it also so it must be a stock part. Directly behind the diagnostic block and right of the Igniter.
#4 | |
![]() Quote:
My 89 doesn't have one???? But damn that is one clean engine bay!!!! ![]()
1995 Toyota Supra SE 71k miles. Master power T70 stock 2jzge 1989 Toyota Supra. 1jzgte swap 5 speed of course.. Driftmotion 60-1 single turbo kit. Cxracing FMIC. 2jz 550cc injectors... soon to come..... EMS Stinger. BC 264 cams 680cc injectors Spec stage 4 clutch and A LOT of boost!------SOLD 1999 Ford F350 diesel 2004 Jaguar XJR Supercharged If it hasnt broke you haven pushed it hard enough!! |
The mystery is solved. Is a relay for the spray headlight cleaner found on '87 and '88 Supras. The part number is: 85276 -22070. It even says "relay cleaner cont." on it.
Duhhh. On a sidenote, how was thinking of using this sprayer as a sprayer for the intercooler instead of the headlights. I think WRX's had a feature like this. |
#6 |
Ah, thanks! Never occurred to me. It was only even an option on N/As from '86.5 up to '88.
I don't know of any car that came from the factory with an IC sprayer, but they're a popular enough mod. Using the headlight washers is pointless unless you get some finer sprayers, more of them, feed it with a better solution than windshield washer fluid, and add a controller (a TPS trigger would do well, so it only sprays when you're at or beyond a certain percentage of throttle).
7mgte engine block | 91mk3 | Parts Wanted | 4 | 10-24-2011 10:36 PM |
HELP!: 7MGTE engine block info needed | barton | MKIII Supra | 1 | 05-19-2010 05:54 PM |
Use 7mgte block as a 7mge?? | joshtexican | MKIII Supra | 22 | 05-05-2010 03:42 AM |
HELP!: 7MGTE engine block info needed | barton | MKIII Supra | 6 | 04-14-2010 09:28 PM |
