Old 02-27-2011, 06:03 AM   #1
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
Default Dropzone Springs?
Has anyone ever heard or used Dropzone lowering springs before? From what i have read, it's either "loving them" or "hate them." The springs lower the vehicle 2inches up front and 1.6 on the rear, however i assume they will lower more once they settle in.
91ma70 is offline   Reply With Quote
Old 02-27-2011, 08:58 PM   #2
Never heard of them and I do tend to get around. After a quick Google though, I'd never touch them. When people recommend you buy new exhaust components, talk of the amazing ever increasing drop magic (see: sag like a bitch) and the fact that they cost $60 to $100 for most models I tend to disbelieve any claims about quality.
Keep in mind that any significant drop will (typically) require new dampers.
Old 02-27-2011, 11:23 PM   #3
91ma70
91ma70's Avatar
I see, what if i get some Eibach or H&R springs can i run them with my currently installed KYB Gr-2 without problems?
Old 02-28-2011, 01:11 AM   #4
It all depends on what you're looking for. The H&R are a more level drop and the Eibach's give a slight raked stance (the rear sits a tiny bit higher... it's really just for looks on vehicles without a solid rear axle). I believe both are progressive rate springs; I know the Eibach's are. If you want firm with still fairly comfortable road feel, progressive is the way to go; If you want a rigid feel which doesn't change in dampening despite the intensity of the load, then linear rate springs are the way to go.
The KYB GR-2's will work fine with the Eibachs (ran that setup for a couple years and really liked it) and it should be just fine with the H&R; Anything with a greater drop than those though and I'd start looking at real performance dampers. If you're looking for a linear rate spring, ST are a very popular choice. They used to have a lot of issues with sagging, but I've hear that they've improved on that.
I need springs curtismoff MKIII Supra 5 03-11-2007 03:26 AM
Eibach lowering Springs: YOUR OPINION please sportriderseattle Non-Generation Specific Questions 0 02-21-2006 03:38 AM
lowering springs chase Non-Generation Specific Questions 2 06-15-2005 01:42 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
