Old 02-28-2011, 12:03 AM   #1
Rob1
Rob1 is on a distinguished road
Default Rod Knock! OR is IT?
My 89 supra was in my garage for a compression test. results were not great, 140,100, 135, 110, 130, 140. So with head in hands i put the coil packs and intake piping and what not back on and fired it up to check a few things.
Here is where it gets interesting, It ran fine for about 1 min, then i headr a knocking noise. Started slow maybe one loud KNOCK every fifteen seconds or so the progressed to a steady, very loud, knocking.
Well i let it idle for about 3 min a week later and it was knocking up a storm. Then like magic is just STOPED! there was still a faint metalic sound but not a knock maybe valve chatter.
So near silence for about ten seconds. then there was one loud KNOCK, after this knock the engine speed fell down to almost stalling, and when the idle came back up the steady knock had returned.
I have repeted this proccess twice now and it follows nearly the same pattern each time.
Any ideas about what it could be? cuz rods dont normaly just stop knocking. any advice would be greatly appreciated thanks
My work in progress!!!
1989 toyota supra turbo targa top 7mgte, Five speed left hand drive.
Rob1 is offline   Reply With Quote
Old 02-28-2011, 01:08 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
Have ya checked your oil?
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 02-28-2011, 03:10 AM   #3
Yes, a knock can be intermittent.... and thus a royal pain to diagnose.
Was the engine warm when you did that compression test? The only way to do a compression test with a cold engine is wet and that's note really the best indicator either. Did you do a wet and a dry test?
If you run the engine and the knock remains long enough pull the spark plug wires one at a time. When the knock goes away or fades significantly you'll know which cylinder is the problem, then you just have to diagnose the one.
Old 02-28-2011, 03:25 AM   #4
Rob1
i did it cold and dry and i did that to see if i blew my head gasket then this started.
Old 02-28-2011, 06:17 AM   #5
The reason for doing it warm is so that the rings will expand and valves will have a more true seating... that way compression escaping past the rings isn't mistaken for bad rings. The wet test (done with the right amount of oil) will only ensure that even less air escapes past the rings; The two (wet and dry) are used to determine the health of the rings. Also, keep in mind that if the air can escape past the rings too easily it'll never get pressed past a small leak in a HG... no good for diagnosis at all in that case.
Old 03-02-2011, 12:26 AM   #6
Rob1
Ok i might re run it. the knock is VERY loud which i thought it was weird for it to be that loud then just vanish ta know.
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
Knock Sensor/Wiring MarkLinRacing MKIII Supra 2 03-23-2010 02:52 PM
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
