Horrible news/ needing advice... So I pulled the motor out of my mk3 turbo and noticed something bad.. There was a very small crack by 2 coolent channels by cylinder 2.. They don't appear 2 be leading into the cylinder how can I fix this? I was going to get the block pressure tested then weld the cracks it has then shave the block to ofcourse resurface and smooth it out.. Is this worth it? Or will the compression and force of the engine f-up the welds and moter if I take this route? .. Should I look into a 1jz swap??
If the cracks are in the head, you could have it welded but it's probably going to be cheaper to just source another.
If the cracks are in the block, it's trash. You can't weld cast iron blocks with any reasonable reliability.... Not saying it can't be done but it usually fails gloriously in no time at all.
Please don't post in the MKIII FAQ. That's for frequently asked questions only. Thread moved to the MKIII general discussion forum.
#4 | |
![]() Quote:
Welding cast iron is a bitch, welding old cast iron can be hell and very unpredictable. There are a couple reasons why most welders will even tell you to forget it... I just can't remember the reasons. :P It's more a matter of penetration and inconsistent density. It can definitely be welded (I suppose that's up for argument but it's not my argument to make), but the couple people in that industry with whom I've spoken on the matter have all said that it's a waste of money and effort.
You'll usually have a horrible time finding a professional welder who will weld a cast iron manifold; Those are small and require less precision. It's not unlike when you crack the exhaust side of a turbo... it's trash. If you can find someone who's willing to weld it the odds are that after the welding and all the milling and boring and flushing that it would still be cheaper to buy a used block and only do a mild rebuild.
#6 | |
![]() Quote:
#7 |
Do you already know yours is bad?
As far as I recall they're no longer available new from Toyota. Used it the only option and there are a number of places you may acquire one. As I would be planning on rebuilding regardless of where it came from I'd look locally for one which I could inspect and measure myself. If you want one that's already rebuilt check the classified ads on the various Supra sites (I think someone posted here with a freshly rebuilt one recently). You could also try contacting Aaron at www.driftmotion.com to see if he has anything. If you're planning on upgrading to forged pistons you may also use a GE block. You lose the oil squirters which are there to cool the stock cast pistons... not a big deal with forged though. You'll also need to have the block drilled for the oil return and supply for the turbo. If you go this route make sure you run a GTE oil pump and not the GE pump.
ct-26 crack | 907mge | MKIII Supra | 1 | 07-02-2010 04:37 PM |
Timing Case Crack! | teedoff00 | MKIII Supra | 1 | 10-20-2007 09:52 AM |
