Old 03-01-2011, 06:03 AM   #1
drod23
drod23's Avatar
drod23 is on a distinguished road
Default water in the hatch problem
i keep getting water in the spare tire area
the hatch seal looks good any other possible way the water can get in???
drod23 is offline   Reply With Quote
Old 03-01-2011, 06:31 AM   #2
Tail light seals or the seal between the hatch frame and the glass or the seal for the rear wiper.
Old 03-01-2011, 06:56 AM   #3
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
sometimes the spoiler screws (assuming that you have a spoiler) will allow water to seep in too; i added RTV to threads to prevent the leak.
91ma70 is offline   Reply With Quote
Old 03-01-2011, 08:01 AM   #4
Good point. The spoiler (both models) are supposed to have gaskets/seals to prevent this.
Old 03-01-2011, 06:37 PM   #5
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
I have had the same water issue lately. What I did was to treat the gasket and hatch where it touches the gasket with Amour All to repel water trying to get in. I also sprayed the rubber grommets that shield wires at the top of the hatch. I used a thin blade screw driver to apply a small amount of silicone to seal the side window trim triangles on both sides at the top where it’s not visible when the hatch is closed. In the spare tire well I keep the rubber plug slightly ajar with tape to allow any water that get in to drain. This has worked well.
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
