Old 03-02-2011, 12:07 AM   #1
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
Default 7mgte, Never problem free
My engine is running fine, it sounds really good and the turbo spools all the way up like its suppose to. But starting today when I hit the gas the engine light comes on ( only when I'm moving does the engine light come on, when I'm sitting still and hit the gas it doesn't come on) and for some reason when I hit the gas while I'm driving the car doesn't seem to get all the power it should; The engine revs fine but it won't transfer the power to the ground and it takes a minute for the full power to come. I've already checked all the hoses around the turbo and there doesn't seem to be any leaks or holes or cuts.
supraheelfan is offline   Reply With Quote
Old 03-02-2011, 02:42 AM   #2
Have you checked the stored diagnostics codes in the ECU yet? Instructions are posted in the FAQ section. I'm betting on a code 52 and possibly an AMF related code.
Old 03-03-2011, 12:07 PM   #3
supraheelfan
My 7mgte was swapped earlier on when I got it:And I'm missing some hoses and I have no idea what type of hoses they are and what their for. I seen a pic of a stock 7mgte and I seen the hoses I'm missing, but I need to know what they are and if they are necessary to have.They are the small hoses that go from under the air intake, to right beside the bov, then on the other side, it goes from somewhere on the valve cover to near the battery somewhere, sorry for the vague directions.Thanks. And I did find out (atleast I think so) that I probably have a vacuum leak after all.
Old 03-03-2011, 07:34 PM   #4
SupraHead
SupraHead is on a distinguished road
Default Your title misleading
i thought your title said 7m-gte NO PROBLEMS....
and it was FREE and i thought you were giving it away lol
SupraHead is offline   Reply With Quote
Old 03-05-2011, 03:40 AM   #5
Photos might help. Are you talking about vacuum tubing, coolant hoses or PCV plumbing?
Old 03-06-2011, 04:26 AM   #6
supraheelfan
Yes, I will post some photos as soon as I can. They are vacuum hoses if I'm not mistaken, but they have never been there and it has never affected the car, I was just wondering why the hell don't I have them and if it IS really affecting the car and that I'm just too stupid to know it. Either or is a good possibility.
Old 03-06-2011, 06:55 AM   #7
Here are the 7M-GTE hose diagrams from the TSRM all taken out and colored.
http://www.cygnusx1.net/supra/TechTips/vacuum_hose.aspx
Some of the hoses will affect operation in ways you won't notice much but they may make a significant difference in the efficiency of the engine. Others will make a fairly big difference which you may not realize as they were wrong from the beginning. It's worth the trouble to ensure they're all run properly and replace them while you're doing it. The OEM vacuum lines often become porous as they age and degrade (on top of hardening and cracking).
Old 03-06-2011, 10:48 PM   #8
supraheelfan
Wow! The hose diagram is awesome thanks a lot.
Old 03-08-2011, 11:53 PM   #9
supraheelfan
I found out that all the hoses I'm missing are Emissions Control hoses that didn't really matter in the first place, at least to me anyway. I thought about it and instead of buying some lowering springs, I'm going for some Godspeed coilovers and the cheapest place I've found is eBay for $600. If anyone knows of a better deal, please let me know.
Old 03-09-2011, 01:08 AM   #10
Are you sure they don't matter? Some of them have extra benefits which you do want (like a cooler running engine).... but also, if some of those items are removed and the hoses aren't properly terminated it will screw things up and cost you power.
$600 for coilovers? Make sure they're rebuildable and you'll probably want to see if you can get the parts in bulk.
need help with 7mgte idle problem MAG.net MKIII Supra 4 09-06-2007 06:10 AM
