Old 03-04-2011, 11:56 PM   #1
Sonyps307
Default 7mge head bolts retorque
I have a rebuild 7mge and it has the stock head bolts torqued to 75lbs. And i was wondering if I should maybe re-torque them. Also the new motor has about 1700 miles on it.
Old 03-05-2011, 12:47 AM   #2
A retorque is always a good idea; It's cheap insurance. Crack loose just enough to avoid striction (binding, non-fluid tightening movement) on the tightening pass. I've posted in more detail about my process of retorquing before, search the word "striction" and you'll probably find it relatively easily... no one sees to know what it is.
Old 03-05-2011, 02:42 AM   #3
Sonyps307
So I should crack them all loose a bit at the same time then retorque in the way the tsrm show or one at a time Crack loose then retorque.
Old 03-05-2011, 03:48 AM   #4
It's just as easy to do them all in order to be safe, but you're not likely to cause any problems by the temporary difference of 5ft lbs on a given bolt. I loosen them all about a quarter of a turn first then I tighten back in order. If one needs a little more backing off (as much as another 1/4 turn or so) in order to get it to tighten down smoothly I'll do it by itself then.
If you lubed them with moly grease when you installed them tighten to 75ft lbs, if you lubed with 30wt oil torque to 80ft lbs... If you didn't chase the threads when you did the HG then just forget it as your torque reading are all going to be way low and you'll be redoing it in a year anyway.
It's good to do it when the engine isn't cold too.
Old 03-05-2011, 04:15 AM   #5
Sonyps307
Well the shop that build the motor installed the HG and head so I don't know if they lubed them or not nor chasing the threads.
Old 03-05-2011, 05:47 AM   #6
I'd be quite surprised (if they're a reputable shop and the work wasn't done by a new apprentice) if they didn't lube all the fasteners and chase the threads; They're essential to accurate torque readings and a good rebuild.
Old 03-06-2011, 06:34 AM   #7
Would you please measure your dipstick and post the length in this thread? Measure from the black rubber stopper to the tip. It would really help another owner and I think I may need to add it to the FAQ... It's come up a few times. Thanks!
Old 03-07-2011, 11:52 PM   #8
Sonyps307
Got it all apart and retorque all the bolts. Then all back together today. So I went to take it around the block and forgot to plug in the TPS and it was revving at 2500 RPMs. So I plugged it in and now it still revs at 2500+ and have code 51. So you guys think I have to redo my TPS again.
Old 03-08-2011, 12:53 AM   #9
I don't know why you're even asking? Yes, try calibrating the TPS again... while you're at it you should test it with a multimeter to be sure it's still functional.
If you still have the high rev issues after you get rid of the code 51 you should start with verifying that all of the vacuum hoses are properly routed.
Remember, having the A/C on or pressing the throttle while in the diagnostic mode will cause a code 51; Same goes for an improperly terminated A/C signal line after deleting the A/C.
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
7M-GTE Head torques on stock bolts... MA70-3.0GT MKIII Supra 2 11-07-2009 04:58 PM
head bolts on jdm engine tone loc MKIII Supra 10 06-03-2007 09:33 PM
head gasket bolts marc MKIII Supra 6 10-23-2006 07:23 PM
ARP head bolts Deputy99 MKIII Supra 2 07-19-2006 11:16 PM
