Old 03-11-2011, 04:41 PM   #1
MK34me
MK34me is on a distinguished road
Default Looking for some info - FFIM upgrade
Hey all, I'm at the point of a rebuild where it gets a bit tricky for me. I want to upgrade to a front routed intake manifold on a 7mgte. I can visualize what has to happen, just dont know the specifics. Can anyone give me some info as to how I re-run the throttle linkage? I think I've got everything else worked out:
1. Re-route the intercooler piping
2. Relocate the BOV to the intake piping (does the vacuum line still run to its original location atop the valve cover or is there a closer spot?)
I know there is more, those seem to be the big ones.
Do I need to relocate anything else? Also, I have upgraded my turbo set up to a racing manifold, HKS turbo w/external wastegate. Where does the vacuum line coming from the bottom of the wastegate run to?
S*^T! I've got the MK3 flu bad and need help to finish this darn project!!!
Help please.............................anyone?
MK34me is offline   Reply With Quote
Old 03-11-2011, 07:26 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Please don't post generation-specific threads in the "Questions, Comments, and Feedback" forum. That forum is designed for threads about the site in general. Thread moved to MKIII forum.
As for a FFIM, I've seen them before for the 7M's. I'll see if I can snatch a pic off the web and link it in here.
Old 03-11-2011, 07:39 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Well, none of the pics I found really show much as to how the cable is ran. From what I've read though, it looks like you can use a cable from some 82-85 efi celicas. Should be 22re's, I believe.
Old 03-11-2011, 10:18 PM   #4
907mge
907mge's Avatar
I believe the alternator will also need to be relocated.
Old 03-12-2011, 02:42 AM   #5
Yes, the alternator and in most cases the battery need to be relocated.
It doesn't matter how you run the cable... If you're unsure get a 1JZ cable and build a bracket or get a universal and cut to fit.
The BOV just needs to go before the throttle body (the closer to the throttle body the better) and it's reference needs to come from a vacuum port AFTER the throttle body.
It's best to supply the waste gate's reference line from as close to the turbo as possible. If you're running a boost controller that will sit in the middle of the line.
Old 03-12-2011, 08:33 AM   #6
btwilson86
Super Moderator
btwilson86's Avatar
I personally kind of like this setup, don't have to relocate the alternator. Battery is definitely gone. Also, don't know what throttle body that is set up for with only 2 studs to mount it.
Tags
information, intake, reroute, upgrade, wastegate
Twin turbo upgrade NU55TY MKIV Supra 3 10-23-2010 02:05 PM
What is the Ultimate Economical 7GTE-M Upgrade??? Bruno Molly MKIII Supra 0 05-10-2009 04:30 PM
Ignition upgrade shiftysupra MKIII Supra 2 11-04-2008 04:00 AM
Upgrade CT-26 or New Turbo MK3Turbo MKIII Supra 2 06-09-2005 02:27 PM
