Old 03-12-2011, 12:21 PM   #1
Life is Supra
Life is Supra is on a distinguished road
Default Boost leak???
Where to look for a boost leak and how do I see it?If can with some pictures please.
Life is Supra is offline   Reply With Quote
Old 03-12-2011, 05:54 PM   #2
Preston
Preston is on a distinguished road
it can be a whole bunch of different problems,
im having problems with my front mount at the minute
Preston is offline   Reply With Quote
Old 03-12-2011, 07:39 PM   #3
graywolf1969
graywolf1969 is on a distinguished road
Default hey man
i dont know if this will work but when you have a vacuum leak on a engine you spray starter fluid on the vacuum lines and it will bring the idle up or down try spraying the intercooler pipeing and holesis .. were you spray it and it does work then thats were your leak is ... this could be lots of outher thing man not just a intercooler leak ... so what is your supra doing so we can help u
graywolf1969 is offline   Reply With Quote
Old 03-13-2011, 09:24 PM   #4
Starter fluid or propane or brake cleaner are not reliable for testing ffor boost leaks. These methods require strong vacuum; Boost leaks however may cause no boost leak as they may only be leaking at 100kPa/s where your engine's vacuum at idle is only around 15kPa/s. To really test for leaks you need to pressure test the system.
http://www.vfaq.com/mods/ICtester.html
Connect one of these and then pump up to 5 to 10 psi higher than you're normal boost level. If the pressure doesn't hold try putting a second one of these (without the nipple) in the other end of the piping to plug the throttle body side. So, plug with nipple on the turbo input and solid plug on the throttle body side. Then hose everything down with heavily soapy water and watch for bubbles. If you see none and the pressure's staying try another 5psi and you're good.
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
Fresh Rebuild. Boost leak? Cinciguy90Turbo MKIII Supra 4 05-31-2010 02:23 AM
Wont accelerate under boost, misfires, backfires, and wont idle Andrew - turbo a MKIII Supra 1 07-24-2009 01:39 PM
Still no boost... drmmr15 MKIII Supra 19 02-08-2007 04:39 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
