Old 03-13-2011, 08:20 AM   #1
861/2nonturbo
861/2nonturbo is on a distinguished road
Default spark plugs are swiming in oil
I pulld out plug wires and it has oil 1/2 way up the plug boot and the old plug boot snaped on the plugs but the new ones dont and they seem to be too long please help STUMPED.
861/2nonturbo is offline   Reply With Quote
Old 03-13-2011, 07:30 PM   #2
You posted this in the wrong section; I'll move it.
Your post isn't easy to understand... What snapped? What's too long? The cable, the boots?
The oil is typically due to leaking valve covers due to loose screws, old seals or both. Do not over tighten the valve cover screws; Only 22 INCH lbs, not 22ft lbs! If you over do it you can crush the gasket or warp the valve cover.
Help...My spark plugs are in the oil !!! chinesedawn MKIII Supra 6 10-03-2011 09:25 PM
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
