Old 03-31-2011, 06:52 PM   #21
Testing procedure for a of the EFI system:
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=30
AFM specific section:
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=94
Fuel system:
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=70
Old 03-31-2011, 08:49 PM   #22
Green7mgte
Supra Forum Moderator
lawl. Did anyone mention they could use an oil drain plug gasket? if so, sorry for the repost.. wtf isnt this in the faq too?
sure is
http://www.toyota-supra.info/forums/...ark-plugs.html
I just replaced the crank case vent hose.. 45bucks from champion.
Only thing to remember is to not over tighten the alternator belt.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-11-2011, 08:00 PM   #23
gaitski
gaitski is on a distinguished road
Update: I haven't had time to research how to check the EFI, but I did check the codes again and found that I've got a code 43. Looks like ignition switch circuit, ignition switch, or the ECU.
Anyone come across this one and had luck with anything in particular?
gaitski is offline   Reply With Quote
Old 04-11-2011, 10:17 PM   #24
Green7mgte
throttle cable?
http://www.toyota-supra.info/forums/...ded-supra.html
http://www.toyota-supra.info/forums/...-and-43-a.html
Supra FAQ
Supra MKIII FAQ
Old 04-12-2011, 01:50 AM   #25
gaitski
Throttle cable seems alright, it's not hanging loose or anything. Is there something in particular to check there?
I disconnected the battery and pulled the ECU out to take a look at it and reset it. When I put it all back together, no codes, but now it isn't starting at all. It cranks fine, but nothing after that.
I'd like to test the ECU, but I'm kind of confused by the Cygnus site. Do I pull the ECU totally out and use a multimeter on it then, or am I testing the plug ends that plug into the ECU?
Thanks!
Old 04-12-2011, 02:42 AM   #26
Green7mgte
tampering with the brains of the car isnt the best idea if were unsure of the outcome / process.
thing with the throttle cable is just it being slack not giving you enough rpms with the peddle to the floor.. would explain your power loss right?
make sure you put the ecu back in correctly. I've removed mine a couple times. You dont need to remove it to reset it, d/c the battery is enough. Just removing the negative cable for a few minutes is enough to reset it. Your car was working fine just a few moments ago yes? just a code 43 that could of been easily checked / replaced.
yes you have the ecu connected (plugged in) and your checking the pins. w/ the key turned to ON
damn you did d/c the battery before removing the ecu right? just precautions there. Its a stout piece of electronics that usually dosn't go bad. make sure you have the connectors in the right spots. But IIRC there all different sizes.. make sure there pushed in fully man.
Supra FAQ
Supra MKIII FAQ
Old 04-12-2011, 03:07 AM   #27
gaitski
Sorry, I've just been assuming that everyone has read the entire thread. Long story short, I replaced my valve cover gaskets and sealed the No. 3 cylinder head cover bolts b/c I had oil leaking into my spark plug wells. Once I got everything together (with new spark plugs), on my third drive on the fix, I suddenly lost all power like I'd shifted into neutral. The engine was still running and hitting the gas pushed the RPMs, but I had no go. I eventually came to a stop and the engine died.
Once I got towed home, the engine would start normally, but die after a few seconds. Hitting the gas would increase the RPMs for those few seconds, but it would still die. I then checked the codes again today and got the 43.
Honestly I don't remember if I'd d/c the battery before I took out the ECU. Did I do a stupid thing there? I guess I don't understand how you get the points of the meter into the pins while they're plugged with....the plugs.
Having heard the whole story, do you have any thoughts?
Thanks for taking the time to respond, I really appreciate it. I would love to hand this off to a mechanic near me, but folks won't touch my truck because of all the customization with the 7mge and all.
Old 04-12-2011, 04:14 AM   #28
Green7mgte
d/c battery
remove ecu connectors
remove LOCKS
Reconnect ecu
reconnect battery
turn power to on
place tester leads.
Supra FAQ
Supra MKIII FAQ
Old 04-20-2011, 10:57 PM   #29
gaitski
Sorry, what are LOCKS? If they are the plastic connectors that lock the wires to the ECU, how do you remove them?
Old 04-22-2011, 03:27 AM   #30
shadowrun
shadowrun's Avatar
shadowrun is on a distinguished road
One time I forgot to hook the vacuume hose up that comes from the power steering pump and connects to bottom of the intake, the engine would start and than die in about a second maby check to see if the hose fell out.
shadowrun is offline   Reply With Quote
spark plug valley colver bolts bassboy3313 MKIII Supra 9 11-27-2010 04:26 PM
spark plug? BlueTuner MKIII Supra 8 05-09-2010 11:21 PM
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
Broken spark plug! HELP! supraman121 MKIII Supra 2 10-02-2006 08:40 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
