Old 03-23-2011, 08:28 PM   #21
El_supracabra
El_supracabra is on a distinguished road
@cre
The head was milled .020" and the block was decked down .007" and the Cometic Headgasket is .051" so essentially its the same thickness as stock (i think, i keep getting different answers on stock thickness) i have also seen stock HG thickness at .053") so in the spirit of being safe we'll say
thats a total of .029" reduction. My understanding is that there is (standard) 1 mm of piston to valve clearance (.03937") (ive also heard that there is 1.5mm but i went with the safer lower clearance)
so that gives me.....*crunching numbers* .01037" of piston to valve clearance. (allowing for some thermal expansion etc. etc.)
Does that sound right?
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
Old 03-24-2011, 09:57 PM   #22
El_supracabra
Default IT LIVES! but....
well we fired it up today! It idles great, but when driving it, it does the EXACT same thing it did before. seemingly runs perfect until you hit exactly 4000 rpm then it starts spitting and stumbling.
I checked the timing w a light and its sitting at 10* advanced w/ a jumper on the diagnostic box.
But, I went through all this with it before the rebuild. It was sitting at 10* so i pulled the DIST and rotated it one tooth, put it back in and set it on 0* it dropped the idle so low it didnt want to run, so i adjusted the idle stop until it was idling around 1k rpm and it ran like crap when i drove it. I ohm'd the igniter/module/coil, throttle position sensor and the pick up coils. tested all of the VSV's and triple checked all wiring connections and vacuum lines. Everything seems to be perfect. could this be an ECU issue?
I think im going to post a new thread on this...
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
