Old 03-19-2011, 12:48 AM   #1
Rob1
Rob1 is on a distinguished road
Default Oem head bolts
Where can i get a set of OEM head bolts with the factory Allen wrench bolt heads? i dont like the ARP studs cuz i had an issue with my old 7mge that i could not get the nuts back off the studs. socket was to fat. Just wanted to replace my factory ones.
Also im rebuilding the bottom end cux i dropped a valve and it destroyed one piston, i found a set of NPR pistons and rings on driftmotion.com for like $140 shipped anyone ever used these? are they ok? using stock rods and OEM quality bearings only pushing about 350whp any suggestions?
Thanks
My work in progress!!!
1989 toyota supra turbo targa top 7mgte, Five speed left hand drive.
Rob1 is offline   Reply With Quote
Old 03-19-2011, 01:16 AM   #2
907mge
907mge's Avatar
There is a set of arp head bolts on here for sale if that helps: http://www.toyota-supra.info/forums/...ead-bolts.html
Old 03-22-2011, 11:09 PM   #3
You can find impact sockets which fit perfectly with a little filing or grinding... but if you want Toyota bolts... well, go to Toyota.
7M-GTE Head torques on stock bolts... MA70-3.0GT MKIII Supra 2 11-07-2009 04:58 PM
head bolts on jdm engine tone loc MKIII Supra 10 06-03-2007 09:33 PM
head gasket bolts marc MKIII Supra 6 10-23-2006 07:23 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
ARP head bolts Deputy99 MKIII Supra 2 07-19-2006 11:16 PM
