#21 |
ouch.... LOL
anyways... ![]() I dont ever remember saying "my cams dont line up"....because they do. perfectly. I triple checked my valve timing, AND my ignition timing. I really dont appreciate "my88isgreat" implying that I didnt "read the book". so.... ![]() Thanks CRE for the useful information. I swapped out the fuel pump relay and resistor with another one and it didnt change anything. I also put a jumper wire on the TPS connector and checked my fuel cut. according to the TSRM (that i actually read ;-) my fuel cut should be at 1800 then return at 1200. My actual fuel cut is at about 2400 and returns at about 1900. This is actually the only thing i can find "wrong" with the car. advice? oh and how do you bypass the relay? by connecting a jumper between +B and PR on the fuel pump relay connector? thanks!!
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL! ![]() CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time FORD- Flipped Over, Rebuilt Dodge DODGE- Dirty Old Dust Gathering Engine I'd rather drive a Toyota, than push a ford. |
#22 | |
![]() Quote:
I don't even own a car, just here for the moral support and friendly people. The Dr. said its good for me. Have a supra day!! |
#23 |
Wrong...the cam timing will be retarded because the cam cog will be closer to the crank cog and will roll CCW a smidge. You can only mill an OHC about .02mm before you need to cut and use a "head saver" shim. these are usually .020" an allow a .020 cut on the head or block to preserve factory valve timing.
#24 |
Bone Stock w Upgrades ;-)
Here are some photos of a uncut and a cut head. The more you cut a head the flatter that rounded part under the thermostat standpipe connection gets. It's something to look for when buying a head. I had my head and block resurfaced and ended up using an old school metal shim gasket under the Toyota factory gasket. I sprayed the bottom of the shim gasket That contacts the block with Prematex copper spray. After 7 years and 35K miles, I haven't had any issues. Alternatively, you could use a thicker stacked metal head gasket alone but you really need to prepare the surfaces first. Here is a link to a company that can supply most any thickness of shim gasket you want. I wouldn't go of more than 0.040" though. It's been discussed in other forums that a 0.020" cut is a small fraction of a degree out of timing. The Toyota manual allows 0.010 but doesn't say anything more than that.
Innovative machine & supply: https://innomach.com/cylinder-head-shims Last edited by Bru; 06-04-2022 at 07:24 PM. |
#25 |
![]() Toyota Racing Development Join Date: Apr 2007
WOW! Resurrected after over 11 YEARS!?!
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
Thread Tools | |
Display Modes | |
Best Cylinder Head Seal | Supra Saiyan | MKIII Supra | 5 | 02-06-2011 01:10 AM |
torque settings for big end shells and cylinder head | johnkarl | MKIII Supra | 4 | 11-03-2006 04:01 PM |
Cylinder Head?? | ZauggIt1 | MKIII Supra | 8 | 10-24-2006 01:51 AM |
Valve Job On Head Now Car Wont Start? | MKIII shujin | MKIII Supra | 4 | 08-07-2006 02:16 AM |
