I milled .020" off of my cylinder head, is this going to throw off my valve timing? do i need adjustable cam gears? please advise.
86.5 mk3 7mge non turbo
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL! ![]() CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time FORD- Flipped Over, Rebuilt Dodge DODGE- Dirty Old Dust Gathering Engine I'd rather drive a Toyota, than push a ford. |
The 7mge is a non interferance motor to begin with, so no. The only thing it will do is raise the compression a bit.
The teeth on the timing belt most likely would not perfectly align due to the shorter gap between cams and crank, so to get timing set perfectly you should use adjustable cam gears. I'm assuming at most they will be a degree or two off, so it may not be very noticeable if you ran without the adjustable cam gears.
I see what you are saying....hmm...well, wouldnt you be able to "take up" the extra slack with the idler adjustment?
when i put it in time, i rolled it over 360* and it seemed to line back up perfectly. Would that cause it to completely fall on its face at 4000rpm and spit and stumble? It will BARELY make it to 6000. and only if i HOLD it to the floor.
see the thread "the unfixable mystery problem". lol EXACT SAME problem
thanks!
#6 |
I would think that that little amount would not throw off the belt that much. After all it is only 2/100ths of an inch. I would think you probably have another problem.
#7 |
Wrong...the cam timing will be retarded because the cam cog will be closer to the crank cog and will roll CCW a smidge. You can only mill an OHC about .02mm before you need to cut and use a "head saver" shim. these are usually .020" an allow a .020 cut on the head or block to preserve factory valve timing.
Best Cylinder Head Seal | Supra Saiyan | MKIII Supra | 5 | 02-06-2011 01:10 AM |
torque settings for big end shells and cylinder head | johnkarl | MKIII Supra | 4 | 11-03-2006 04:01 PM |
Cylinder Head?? | ZauggIt1 | MKIII Supra | 8 | 10-24-2006 01:51 AM |
Valve Job On Head Now Car Wont Start? | MKIII shujin | MKIII Supra | 4 | 08-07-2006 02:16 AM |
