Old 03-29-2011, 09:59 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Default JZ Code 14 IGf signal Help please!
Hey guys. I'm gettin a code 14 on my 1jz. I checked capacitors and they are good! It will fire up for half a second then shut off. And I get the code 14 I know its not a 2j but they share the same codes and components. I have repaired the coils with nail polish and thick heat shrink and they were working excellent not cutting out at all. I was Jus driving slow getting out of the base when it shut off. I have checked fuel pump and wiring neither is faulty. Any suggestions would be great. The $4 a gallon is killing me in my truck!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 03-30-2011, 10:43 PM   #2
Travis89Turbo
Does anyone kno how to test a 2jz igniter?
stock 2jzge
Old 04-02-2011, 02:53 AM   #3
Unfortunately, there's no way to test it. If your ecu signal, coils and plugs are all good, you have to borrow/buy/steal(just kidding)/etc. another ignitor and swap it out.
Old 04-02-2011, 07:27 PM   #4
Travis89Turbo
OK so I did a continuity test on the wiring to the ecu to the igniter IGf signal wire (red-blue) and it checks good! I then was tryin to check for voltage goin into the ecu... I'm not sure exactly how the IGf signal is suppose to be. But as soon as I turn the key to "on" I get a solid 5.0v. To me that doesn't sound right. I kno 5v is its operating voltage but shouldn't it only give voltage when the igniter is giving a feedback signal and not when key is Jus in on position?
The supra community is very small here in Utah. And especially for 1j or 2j. So the only way I could try it is by buying one. Which if it comes to that I will I just want to try and narrow it down to either ecu or igniter. The ecu on 1j are very problematic but usually its just the caps that go out and when they get replaced they usually work again. But it is not unheard of for it to go out completely. I have had it apart and traced the wire tracks and everything seems to be in order with no corrosion from melted caps anywhere. The only ecu for a 1j I can get is either oem used from Japan for $650 bucks or a standalone. I was planning on goin with an EMS stinger but thats $900 plus dyno tune. I wanted to wait till I had bigger injectors before i did that so I didn't have to re-tune when I do. And right at this moment thanks to the beautiful tax system I owe them 1k this yr so money is tight.
I appreciate the help. Do you think the 5v out of the igniter feedback constant is normal?
stock 2jzge
Old 04-04-2011, 05:54 PM   #5
Travis89Turbo
I ordered a 2j igniter for $65 so we will see in a few days!
stock 2jzge
Old 04-10-2011, 11:12 AM   #6
I agree that the 5v constant signal out of the ignitor seems abnormal.
Wow that's a great price. A brand-new 2jz-gTe ignitor should be over $400 iirc (are you sure you have the correct partnumber? )... Either way, I sure hope this corrects the issue for you!
Old 04-10-2011, 10:36 PM   #7
Travis89Turbo
Yes, it was a used part! But unfortunately that was not my problem, it did the same thing?? so I was lucky enough to find an ecu for 300 shipped. I'm almost positive this is the problem. If not i can always resale it for atleast what I paid.
I did recheck my coils and plugs everything checks good and is within limits. So I will let ya kno if the ecu resolves this issue! There is really nothing else that is related to the Igf circuit!
Oh BTW. I have a 97 tt igniter for sale!
stock 2jzge
Old 04-13-2011, 02:57 AM   #8
sorry travis I would really like to help but I know jack shit about 1jz's. So im not even going to attempt to chime in.. this is the only thread on page 1 that dosnt have a post by me in it.. OH, this one and one other but I dont think that guy was speaking english.
Old 04-13-2011, 03:14 AM   #9
Travis89Turbo
Haha. You crack me up Green....
I ordered my ecu from kaizen motorsports. I was hoping to see it today but no luck. hopefully tomorrow.
What do ya think bout the swap thou? As you can see my stock twins took a shit 2k after I had it rolling. So I went with the sick ass driftmotion kit!
stock 2jzge
Old 04-13-2011, 03:39 AM   #10
i dont know man. I would love to get my hands on a driftmotion turbo but my savings keep on going to other things..
all in all im Green, with envy. lucky bastard. way to go man.
Damn code 51/31 Supra Saiyan MKIII Supra 10 02-15-2011 10:57 AM
Well... Another code.. Cyto MKIII Supra 1 02-02-2010 12:21 AM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
No Signal to Fuel Injector ithinkitwassumthini8 MKIII Supra 3 09-12-2006 06:35 AM
