Old 04-10-2011, 08:31 PM   #11
manrique112
manrique112 is on a distinguished road
I did some manual reading so i now know somethings about my supra. In regards to the idle problem, I bought a new TPS and it fixed the problem. My main concern now is the car stalling without notice. One of the codes shows a bad AFM.. what are the symptoms of a bad afm?. want to make sure before I make a costy purchase.
manrique112 is offline   Reply With Quote
Old 04-18-2011, 04:39 AM   #12
Unplug the AFM and go for a drive. Just don't get into a race. If it drives close to fine then the AFM is shot (note: this only works on the 7M-GTE models).
There's more testing info in the TSRM, but if driveability improves with it disconnected then it's pretty much given that it's shot.
Old 04-20-2011, 12:09 AM   #13
manrique112
Thanks for the information. I ended up buying an AFM. car runs perfect. I wish I could find out who was the idiot who put this engine tho. So far I have bought the following.
1. new TPS
2 new recirculating kit for my BOV
3. new AFM
4. New CPS dust cover and gasket(cps had been exposed due to a broken cover)
5. New vacuum hoses.
6. New universal Oxygen sensor
one problem remains; the car shuts off without notice, then it start right up it has happened 2 times while cruising on the street. I don't have any codes in my car so I don't know where to start.
Old 04-25-2011, 01:34 AM   #14
Dying while the throttle's open, at tip-out or at idle? Stumbling or just smoothly cutting out? Have you checked all grounds and power connections (including at the ECU)?
Old 04-25-2011, 01:09 PM   #15
manrique112
The car suddenly sutts off during a hard stop. Although not all the time, the car dies if I make a sudden stop, it will die but the cluster lights will stay on. Besides that cars is a mean machine, draining my cash on gas..4.40 a gallon, gotta love New York.
Old 04-25-2011, 06:50 PM   #16
The BOV venting to atmosphere is a very likely cause of the stalling at tip-out (cutting throttle quickly).
Old 04-26-2011, 12:25 AM   #17
manrique112
I have a recirculating kit. I was thinking the same but anything else?..
Possible supra owner questions! Zanark MKIII Supra 2 08-24-2007 06:01 AM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
