Old 04-02-2011, 01:54 PM   #1
Cinciguy90Turbo
Cinciguy90Turbo is on a distinguished road
Default Code 22 41 and 51 replaced parts still has CEL
I've been having some rough idling issues, stalling and falling on its face during acceleration. The CEL says that its 22, 41 and 51. I have tried adjusting the TPS, and the same results continue, so I bought a new one and put it on as well as a new coolant temperature sensor and thermostat (the car would not heat up past 160 degrees). It is now running at 195 or so but the CEL is still on for all three codes. I have tried resetting the ECU by unplugging the battery until the clock and radio reset. It seems to be running a little better but I drove about 40 miles and used about 4 gallons on gas. It stalls less, and idles a little better. If anyone can point me in any direction it'd be greatly appreciated.
Cinciguy90Turbo is offline   Reply With Quote
Old 04-02-2011, 08:35 PM   #2
Code 41 isn't something you adjust for... it's flat out a bad TPS, ECU or wiring.... TPS and bad wiring being the more common two and TPS being the most common of all.
You don't need to disconnect the battery entirely to reset the ECU, the EFI fuse does the same job and you don't have to reset the clock and your stereo settings.
Old 04-02-2011, 08:46 PM   #3
Cinciguy90Turbo
Is replacing the wiring an electrical nightmare, since I just changed the TPS? And would that be why I have a "bad" coolant temp sensor as well?
Old 04-03-2011, 01:56 AM   #4
The have a common ground:
http://www.cygnusx1.net/Supra/Librar...px?S=Main&P=48
Start testing.
Old 04-03-2011, 01:21 PM   #5
Cinciguy90Turbo
so the best way to do that is to unwrap it and start probing with a multi meter.
87 MkIII vs 89MkIII -- parts interchange willblock MKIII Supra 5 07-24-2016 06:27 PM
Collection of Sources for Parts for the MK3 tangsuto MKIII Supra 0 08-17-2009 04:21 AM
