#1 |
Just finished 7MGE swap to 7MGTE motor fired up fine,just one issue motor has a miss sounds like bup bup intermittently also at the exhaust tip,motor has 60000mls check torque came it at 75-80lbs boost leaked checked and replaced hose clamps,coil pack good new plugs all firing good,I had two suggestions #1 replace fuel pump- injectors are not getting enough fuel,#2 possible tight exhaust valve seeing that the sound comes from the exhaust also.Anyone knows what can be causing this? dont want to start messing with valves /fuel tank unless i have to. Thanks
7MGTE to 7MGE | karu | MKIII Supra | 4 | 10-22-2010 07:22 AM |
7mgte front clip | supraman121 | MKIII Supra | 4 | 05-31-2007 01:27 PM |
7mgte and 7mge question | supraman121 | MKIII Supra | 2 | 01-12-2007 09:09 PM |
7mge to 7mgte | kallmijonx2 | MKIII Supra | 2 | 10-22-2006 12:55 PM |
