Old 04-08-2011, 06:05 PM   #1
Awyman18
Awyman18 is on a distinguished road
Default Blown headgasket?
OK, so i recently bought a 1990 toyota supra turbo. has about 98k miles and ran great, until i was spewing engine coolant, hearing bubbles behind dash, and loss of power. Im pretty confident the hg is blown. This thing is basically bone stock besides a k&n air filter. I plan on tearing it apart and buying a whole gasket kit but i dont kno which one to buy? i dont plan on modding it either, and its stil running stock boost. Help please????
Awyman18 is offline   Reply With Quote
Old 04-08-2011, 08:29 PM   #2
Green7mgte
Supra Forum Moderator
the HG is defective from the factory. too low torque specs.
do you have milky looking oil on your dipstick? do you have oil in your overflow? those are signs of a BHG. tons of info on what to look for in the faq, give it a browse.
The bubbles behind the dash is air in your heater core. The heater core is located behind the dash and is lower then your rad cap. so air will travel through the system and collect in the HC making that waterfall sound you hear. all other issues aside if you jack the front end up and remove the rad cap and let the car warm up for 15 minutes adding fluid it will "burp" your coolant system. also covered in the FAQ (or it should be)
as for your gasket kit. just get the one for the 7mgte.
Good luck man.
http://www.toyota-supra.info/forums/...-symptoms.html
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-09-2011, 01:39 PM   #3
Awyman18
hey no theres no milky oil, nothing in the radiator, so i caught it really really early, but idk if i should get the stock hg because ive heard its alot more forgiving? Instead of a metal one
Old 04-09-2011, 01:44 PM   #4
Green7mgte
you don't need a metal HG. not unless your planning on running 30# or more of boost. A larger question you should be asking yourself is do I want bolts vs studs.. bolts are fine and thats what ive used. studs are better but not defiantly needed. just remember to torque them above spec.
Supra FAQ
Supra MKIII FAQ
Old 04-09-2011, 11:25 PM   #5
Awyman18
hey and no i plan on keeping it at its 6-7# of boost, but i think im going to get studs, but ive seen like..stone Hg's, and graphite hg's and wondering..like wats the difference, etc etc, wat HG do u have ur supra by chance? and wat should i torque the bolts or studs to depending on wat i get?
Old 04-11-2011, 12:49 AM   #6
Green7mgte
cosmetic hg w/ stock bolts torqued to..shit idk 85lbs? i dont recall. studs are what.. 95.. who said 112?
Supra FAQ
Supra MKIII FAQ
Old 04-17-2011, 01:46 AM   #7
mkiiisupra
Do your self a favor and when you go to reoil/clean that K&N toss it in the trash instead and by a good Dry flow air filter from AEM, HKS or even stock.
The K&N are notorious for not only allowing too much debris into the engine... Also there is probably a 80% chance when you reoil it that its going to destroy your AFM.
1990 Toyota Supra Turbo A/T
Old 04-24-2011, 06:57 PM   #8
Awyman18
well ill will be changin that for sure then lol thanks
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
Blown Headgasket? or no? Jay633 MKIII Supra 6 04-24-2010 06:32 PM
89 Turbo 5sp blown headgasket for sale Ms89Turbo5sp Buy/Sell Cars 1 03-26-2010 10:09 PM
copper gasket sealer on fel-pro headgasket? skadaloz MKIII Supra 0 04-10-2009 12:04 AM
How to do a HeadGasket Job SupraSaver87 Non-Generation Specific Questions 3 09-08-2006 02:22 PM
