Old 04-18-2011, 06:58 AM   #1
Boeing787D
Boeing787D is on a distinguished road
Default my coolant leak
I recently had a complications of my Supra leaking a coolant. I checked the radiator itself and it didn't show any leak. Also, I checked 2 large hoses from the radiator, also doesn't show any damage. I figured, water pump? Could be the water pump gasket? Please let me know, my car is 1986 Supra MK3 Manual.
Boeing787D is offline   Reply With Quote
Old 01-15-2012, 02:32 AM   #2
BlackEquinox
BlackEquinox's Avatar
BlackEquinox is on a distinguished road
I'm having the same problem only I'm sure it's coming from a bad pump gasket. I'd like to know if I should use a straight gasket or if I need anything like liquid gasket as well? I just want to make sure if I do this that it will take care of the problem and not leak again. Mine is an '87.
BlackEquinox is offline   Reply With Quote
Old 01-15-2012, 04:20 AM   #3
If it's an uncoated, paper gasket I always use a good gasket dressing... This isn't the same as trying to pack in 5 tablespoons of RTV form-in-place-gasket silicone. Whatever you use just a very thin coat is all you need... I prefer spray dressings for uniformity and to prevent buildup. Make sure it's coolant compatible... they're rare but some dressings are not compatible with some of the ingredients used in coolant.
Old 01-15-2012, 11:59 AM   #4
BlackEquinox
Thumbs up
Thanks a bunch!
Old 01-17-2012, 03:27 AM   #5
Crazysupra
Crazysupra is on a distinguished road
There is a small hose behind water pump. It sets by the exhaust manifold and drys out. I have replaced it on mine twice in four years.
Crazysupra is offline   Reply With Quote
Old 01-21-2012, 10:18 PM   #6
BlackEquinox
also another question... Would it be best to change this gasket in warmer weather? I figure there's a lot more expansion/contraction in the winter when the car warms up rather than in the summer when the temps are closer together?
Old 01-21-2012, 10:20 PM   #7
BlackEquinox
Thanks I'll have a look at that too.
Old 01-21-2012, 10:22 PM   #8
BlackEquinox
Could you recommend anything specific? What's the stuff you use?
Old 01-23-2012, 12:53 AM   #9
My preference is Hylomar's sealants. Hylomar Universal Blue is good for most applications. They make a spray which I prefer for HGs but it's nearly impossible to find. Hylomar Advanced Formula (solvent free) is supposed to work very well too, it's free flowing so you want to use as little as possible because what doesn't fit into surface imperfections will press out... I would apply either by just wetting the gasket and apply to the metal surfaces with the edge of a business card to squeegee in just enough.
http://www.hylomarsealant.com/_resou.../products.html
They got hard to find for a while but Mopar sells their universal blue under the name Mopar Hylomar.... and it seems Permatex now has licensed the sealant as well.
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
Coolant leak sd88supra MKIII Supra 6 09-22-2010 07:16 PM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
88 Non-Turbo coolant leak Tazman3653 Non-Generation Specific Questions 1 03-30-2009 02:09 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
