-   -   couple ?'s (http://www.toyota-supra.info/forums/mkiii-supra/18984-couple-s.html)
87supra7mgte 04-18-2011 02:22 PM
couple ?'s
Bought an mkIII and am replacing the head gasket, have everything disconnected I think to pull head off, its not budging, only thing I haven't taken off is the 4 huge allen key bolts in middle, would those prevent it from coming off? If so what size are they? This is the only thing I can think of that's not letting me pull it off, I don't want to put a screwdriver to aluminum head but its lookin like that might have to be an option as well
Travis89Turbo 04-18-2011 04:22 PM
No the spark plug galley cover does not hold the head on the block. Triple check that u have all the head bolts removed. How many have you removed?
I have had to use a pry bar before but it broke free pretty easily. I bet there is still a few bolts holding it down. Some are kinda hidden!
