Old 05-08-2011, 08:22 PM   #71
Sonyps307
If u over filled it and the seals were working right and the shaft was in right It would not leak
Old 05-09-2011, 05:57 PM   #72
ochowdero
i replaced the seal... fixed
the turn signals...fixed
clutch... fixed
now the reverse lights,
can anyone confirm the wires i gotta splice into to get my reverse lights working?
i rthink its orange and blue?
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 05-09-2011, 07:45 PM   #73
btwilson86
Super Moderator
btwilson86's Avatar
The 2 wire colors (at least for an 89) are Yellow and Red/Black. EDIT: I just looked at the harness I have for an 87 N/A Auto, and it's the same colors. You can't just splice the wires together, otherwise your reverse lights will always be on. The page for the TEWD is here.
You need to extend these wires from the engine wiring harness so that they will reach the backup light switch on the manual transmission. If I'm reading the TEWD correctly, the plug on the wiring harness that feeds the signal to the transmission should be connector "A" (located at the bottom of the page linked). The plug that receives the signal from the transmission on your wiring harness is connector "B". The yellow wire is pin 5 in connector A (referred to as A5), red/black wire is B1.
On your manual transmission is a small 2-pin connector (labeled as "C" on the TEWD). You want to connect A5 with C2, and B1 with C1. Once again, the TEWD shows which pin is which at the bottom of the linked page.
After doing this, your backup lights should work as designed.
Now I just hope all that makes sense lol
Old 05-11-2011, 08:19 AM   #74
ochowdero
this all makes perfect sense haha
quick question..
i know my rpms are gonna be all messed up but.. how will my gas mileage be affected?
will it get worse? seems like gas is being killed haha
also, on the freeway i normally would cruise at 80mph but my car is going 80mph @3500 rpms so now i cruise at 75mph @3000 rpms
is that normal for these cars.?
again i know the rpms will be off... and if thats way off how can i correct it?
i really want turbo
Old 05-11-2011, 08:27 AM   #75
ochowdero
also the shifting feels weird..
like its rough sometimes..
lol
idk how to explain im just thinking its alil hard to get through gears becuz its a rebuilt trans..
is that it?
i really want turbo
Old 05-11-2011, 05:35 PM   #76
btwilson86
Super Moderator
btwilson86's Avatar
That sounds right for a N/A 5 speed. That's about where mine is at anyway
Old 05-11-2011, 07:48 PM   #77
lol
is that it?
your shifter bushings may just be worn out, or non existant.
check out on celicasupra.com or at a toyota dealer for new bushings
Old 05-12-2011, 06:55 AM   #78
ochowdero
bushings like this?
http://www.marlincrawler.com/transmi...t-lever-socket
and this
http://www.marlincrawler.com/transmi...ver-ball-seats
i really want turbo
Old 05-12-2011, 08:33 AM   #79
btwilson86
Super Moderator
btwilson86's Avatar
Yeah, those are the ones that you needed to get for that tranny and your shifter.
Here are the Toyota part numbers:
Shift lever seat bushing:
33505-35020
Shift lever bushing:
33548-31010
You can buy them direct from Toyota, or there are a number of websites you can buy genuine parts for less, such as toyotapartscheap.com
Old 05-12-2011, 02:28 PM   #80
can probly get the bushings cheaper from celicasupra.com
http://www.celicasupra.com/forums/sh...ft-Bushing-Kit
manual transmission frostburn MKIII Supra 9 08-18-2008 05:59 AM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
