Old 04-20-2011, 07:49 PM   #11
87hilux7mge
87hilux7mge's Avatar
hmm, id say bad sensors somewhere or bad ecu wiring, but that is pretty puzzling...hell just buy a standalone, then u can tune it all lol. sorry dont mean to take your situation lightly. good luck with it!
Old 04-20-2011, 07:51 PM   #12
cfurlan
cfurlan is on a distinguished road
How hard is it to get to the ecu, I have a spare one from my parts car that I can put in it. Same year engine and tranny.
cfurlan is offline   Reply With Quote
Old 04-20-2011, 07:55 PM   #13
87hilux7mge
should be on the pass side under the dash or kick panel. i think its behind the glovebox area, shouldnt be too hard to get to.
go get a haynes manual for it, 20 bux well spent. itll tell you where most of that craps at.
Old 04-20-2011, 07:57 PM   #14
cfurlan
I've got a Haynes manual but couldn't find the ecu location.
Old 04-20-2011, 08:00 PM   #15
cfurlan
What would be a good standalone to buy?
Old 04-20-2011, 08:45 PM   #16
cfurlan
I switched out ecus and it ran but not great. It revs up to 2500 rpms before idling down to 400 rpms and then barely runs. Giving it gas it has a lot of hesitation.
Old 04-20-2011, 10:32 PM   #17
Sonyps307
Check the tps and wiring
Old 04-20-2011, 11:31 PM   #18
cfurlan
I checked the tps and the wiring to it. I also tried adjusting it while it was running, but it didn't get any better.
Old 04-21-2011, 12:46 AM   #19
vbryanv
vbryanv is on a distinguished road
I had a similar problem. With mine I could not keep the rpms at 1500, and when I took my foot of the gas pedal the idle would fluctuate between 400 and 600 rpms...
I had i bad IAC.
vbryanv is offline   Reply With Quote
Old 04-21-2011, 08:24 PM   #20
cfurlan
I will try and put a spare iac in today to see if there are any changes.
What turbo would give me the most power at 6-8psi supraman121 MKIII Supra 9 09-11-2007 12:45 AM
I give up... EpilepticPuppy MKIII Supra 13 09-08-2007 06:45 PM
head gasket gone would it give oil in turbo intake johnkarl MKIII Supra 7 10-31-2006 06:38 PM
Can some of you guys give me some info on these cars? Big Jimbo MKIII Supra 5 01-07-2006 08:24 PM
parts that will give me the biggest hp increases wikdMK3 MKIII Supra 6 05-04-2005 03:42 PM
