Old 04-20-2011, 06:54 PM   #1
graywolf1969
graywolf1969 is on a distinguished road
Default ? manuel boost control
Hey guys my bros friend has a 1990 supra 7mgte he blew my doors off and he had a 7mgte with a manuel boost control is that bad for your turbo i just wan't to know if its a good way to get more hp with out messing any thing up
graywolf1969 is offline   Reply With Quote
Old 04-20-2011, 08:34 PM   #2
Manuel is the guy in the Paint department of my Home Depot... he's got a small band, they're VERY good, I was rather surprised... you know, generally you hear "I play guitar for a small local band, you should stop by sometime" it's usually a complete horror... I was pleasantly surprised.
Anyway, you mean manual and it depends on how healthy everything else in is. Depending on the weather an otherwise stock 7M-GTE will hit fuel cut between 13 and 15psi. I wouldn't go past 10 or 11psi unless everything else has been tested and PROVEN sound.
Old 04-20-2011, 10:03 PM   #3
Green7mgte
Supra Forum Moderator
ahh hahaha
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
boost control southernsupra Non-Generation Specific Questions 0 04-25-2006 04:11 AM
Manual boost control (bleed valve?) sexy91tt MKIII Supra 1 01-28-2006 05:42 PM
manual boost control in cab joel w MKIII Supra 2 09-18-2005 03:48 PM
Boost control settings JZA70 MKIII Supra 1 05-18-2005 02:08 PM
