Old 04-27-2011, 01:16 AM   #1
ryan0106
ryan0106 is on a distinguished road
Default boost causing bog
i bought this car with it having an issue. when the boost builds up it causes the motor to bog out. i have checked all the vacuse lines and the CEL ligh was on so i did the new TPS and both knock sensors are gettin switched very soon. now back to the engine. it runs great when the boost is not built up but ass soon as it does it just bogs right the hell out. where should i go now? i already went threw the vacume lines and replaced them all. im new to turbos and i need guidence.
ryan0106 is offline   Reply With Quote
Old 04-27-2011, 06:35 PM   #2
87hilux7mge
87hilux7mge's Avatar
boost leak somewhere? maybe cre can shed some light. have you searched yet?
Old 04-27-2011, 08:19 PM   #3
Green7mgte
Supra Forum Moderator
my asshole is itchy.. cre can you hold this flash light and shine it. tell me if I have a hemorrhoid.
damn that shit pisses me off. Hey how about we just rename the forum to CRE please answer my questions.. obviously no one else here is able to..
could be acouple things. you said you were or werent throwing any codes? give it a check. make sure all your spark plug wires are secured. (snug) and I would check you're fuel pressure.
if your checking for boost leaks the most common areas are the Charge pipe right off the bottom of the turbo and the couplers at the 3000 pipe..
You said you just bought this car.. Did the previous owner do anything to the waste-gate to throw more then stock boost? allot of boost and not enough fuel will bog your engine down, running lean does the same.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-01-2011, 09:54 PM   #4
STR
STR is on a distinguished road
Originally Posted by ryan0106 View Post
-when the boost builds up it causes the motor to bog out.- it runs great when the boost is not built up but ass soon as it does it just bogs right the hell out.
i am having the same exact same problem! Need help. New to turbo engines
STR is offline   Reply With Quote
Old 05-01-2011, 10:54 PM   #5
87hilux7mge
sounds like either a boost leak or over/under fueling. most likely under fueling unless your FPR is boned. then youd basically be shoving fuel past the injector pintle.
another possibility is bad KVAFM. check up on the TSRM to see how to test it, youll need a multimeter.
ohming the injectors wouldnt be a bad idea either while your checking.
just another quick thought, check to see if your wastegate is working properly
good luck!
Old 05-02-2011, 12:26 AM   #6
STR
i just pulled a code 52 so i am guessing that might be my problem?
Old 05-02-2011, 01:06 AM   #7
Green7mgte
wouldnt hurt to fix it..
http://www.duanesmith.net/87tknknew.html
found that, seemed helpful..
Supra FAQ
Supra MKIII FAQ
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
Wont accelerate under boost, misfires, backfires, and wont idle Andrew - turbo a MKIII Supra 1 07-24-2009 01:39 PM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
