Old 05-11-2011, 03:28 PM   #1
travisvwright
travisvwright is on a distinguished road
Default Tire Size for '90 stock wheels.
I'm needing to drive a supra that finally runs (but still needs some work) 150 miles. In the years it's been being worked on the very run down tires now have some dry rot. So I'm hoping to replace them for super cheap just to get me 150 miles. The only local used tires I can find are 225 70 16 (where what's on the car is 225 50 16). Will these work?
travisvwright is offline   Reply With Quote
Old 05-11-2011, 05:37 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
They should work on the rear, there's a good possibility that they will rub on the fronts while turning. Also this is assuming you have a stock suspension.
Keep in mind, the larger tires on the rear will affect the accuracy of your speedometer
Old 05-11-2011, 05:56 PM   #3
travisvwright
Thanks for the info. Yes the suspension is stock.
Old 05-11-2011, 10:07 PM   #4
907mge
907mge's Avatar
It is not a wise idea.
225 50 16= overall diameter of 24.86
225 70 16= overall diameter of 28.4
The result will be a higher center of gravity and more sidewall. That means your handling will suck and not to mention your speedo will be off by 10mph.
Use a tire calculator like this one to compare sizes:
http://www.discounttire.com/dtcs/infoTireMath.dos
What is the size of the stock sub in the 1993 toyota supra? Bl@ckh3art Car Audio and Alarms 1 08-05-2013 05:47 PM
Question about the stock wheels mkiiisupra MKIII Supra 6 03-06-2008 03:23 AM
Tire Size for stock 16x7 sportriderseattle Non-Generation Specific Questions 4 12-06-2005 04:22 AM
