Old 05-13-2011, 08:29 PM   #1
jettajay
jettajay is on a distinguished road
Default Diagnosis needed...engine sound
Need your diagnosis please. I'm not sure what this is, but it's the first time i'm hearing this. This is my first supra, and I tried searching if anyone else had posted a video with same kind of problem but couldn't find.. Anyway, I just had a rewiring of the knock sensors, and after the turbo wasn't working and the engine started making this sound when accelerating.
http://www.youtube.com/watch?v=14WlbCf6rYo
http://youtu.be/14WlbCf6rYo
jettajay is offline   Reply With Quote
Old 05-13-2011, 11:12 PM   #2
Care to elaborate on this?
Have you experienced any significant power loss? I can't really tell much from the video... is it rattling? Have you checked for exhaust leaks, debris in the exhaust, loose heat shields or something floating in the valve covers? Also make sure the bolts for the cam gears and the harmonic balancer are all properly torqued.
Old 05-13-2011, 11:39 PM   #3
jettajay
yes, I did experience power loss. didn't check the exhaust for debris, will check again and if there is something floating in the valve covers.
Old 05-13-2011, 11:45 PM   #4
What happened to the turbo?
Tags
engine, noise, odd, sound, weird
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
Engine Wiring Harness NEEDED! slowryders MKIII Supra 4 07-04-2008 07:59 PM
Well crap! Advice needed with shot engine finaltable MKIII Supra 10 03-13-2008 07:35 PM
