Need your diagnosis please. I'm not sure what this is, but it's the first time i'm hearing this. This is my first supra, and I tried searching if anyone else had posted a video with same kind of problem but couldn't find.. Anyway, I just had a rewiring of the knock sensors, and after the turbo wasn't working and the engine started making this sound when accelerating.
http://www.youtube.com/watch?v=14WlbCf6rYo http://youtu.be/14WlbCf6rYo |
Care to elaborate on this?
Have you experienced any significant power loss? I can't really tell much from the video... is it rattling? Have you checked for exhaust leaks, debris in the exhaust, loose heat shields or something floating in the valve covers? Also make sure the bolts for the cam gears and the harmonic balancer are all properly torqued.
yes, I did experience power loss. didn't check the exhaust for debris, will check again and if there is something floating in the valve covers.
What happened to the turbo?
Tags |
engine, noise, odd, sound, weird |
HELP!: 7MGTE engine block info needed | barton | MKIII Supra | 1 | 05-19-2010 05:54 PM |
HELP!: 7MGTE engine block info needed | barton | MKIII Supra | 6 | 04-14-2010 09:28 PM |
Engine Wiring Harness NEEDED! | slowryders | MKIII Supra | 4 | 07-04-2008 07:59 PM |
Well crap! Advice needed with shot engine | finaltable | MKIII Supra | 10 | 03-13-2008 07:35 PM |
