#11 |
Also, I should mention that the problem is very intermittent. sometimes it will run fine for 20-30 miles without it happening. Other times it will happen all day long. Never happens for the mechanic of course.
#12 |
Post specifics for your car when asking for help with problems: Year (done), engine (even if it's an '86.5 if could still have a swapped in 7M-GTE or other engine), and any engine related mods (fuel controller, turbo upgrades, afpr, BOV and how it's plumbed...
GE fuel pumps are just as reliable as the GTE fuel pumps... except for when they're being forced to work overtime from a N/A-T or similar upgrade. What's the ignition timing set at and is it set right? Disconnect the O2 sensor next time it occurs and see if that changes anything. Test the ECU temp sensor in the kitchen with a pot of water on the stove and check at several temps. Good luck with it! ciao
#13 |
Hrmn.. I wouldn't know bud. I'm still learning a lot about my supra. I'm cleaning my header right now then sending it to get resurfaced before I give it one more cleaning. Good luck mate.
Tags |
engine, hesitation, idle, stall, stumble |
Engine Help! | born2drv | MKIII Supra | 9 | 02-01-2011 08:14 PM |
rebuilt hard to crank (high engine resistance); need advice | cbrewster | MKIII Supra | 4 | 09-28-2009 04:52 PM |
problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
subtle shuttering when accelerating on a brand new engine | suprascoot | MKIII Supra | 2 | 07-24-2007 11:27 AM |
