#11 |
I had code 24 but I swapped the afm from my friends car and made no difference..how would I eliminate the afm?
1986.5 Supra Manual Red Mica(Maroon) w/wing: Custom sound system, 18" Tork Revos, smoked tail lights, markers, and turn signals. Mods: Eibach lowering springs, Energy poly front upper and lower control arm bushings, custom cold air intake, solid engine mounts, Magnaflow, short shifter, Optima Red Top, other custom fabrications..and yes a bra. |
#12 |
![]() Toyota Racing Development Join Date: Apr 2007
On a GE? With more money than the car is probably worth.
![]() Get the code 24 taken care of. In case you forgot you do have to pull the EFI fuse to reset the ECU after swapping the AFM and if you disconnect the AFM while the ignition is on it'll set a couple codes including 24. Otherwise you've got a wiring or ECU issue which you need to fix no matter what else you do.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
Thread Tools | |
Display Modes | |
