Old 05-20-2011, 06:55 PM   #1
pandrade
pandrade is on a distinguished road
Default do it yourself upgrades
hey i got a 87 7m gte whith 5 speed and limited slip. I have put on a 3 1/2 inch exsaust on it ( full system from turbo on down) it has no restrictions no cats. are there any other cheap upgrades out there? my local junk yard has 4 supras from which to take parts from all non turbo and automatic
give any tips if you have any
pandrade is offline   Reply With Quote
Old 05-20-2011, 08:26 PM   #2
graywolf1969
graywolf1969 is on a distinguished road
Default Manual boost controller
you could also put a MANUAL BOOST CONTROLLER on your supra like this one on ebay http://cgi.ebay.com/ebaymotors/TURBO...Q5fAccessories
graywolf1969 is offline   Reply With Quote
Old 05-20-2011, 08:29 PM   #3
graywolf1969
FOR ever 1 psi you boost is 11hp dont go over 11psi on your supra it cuts the fuel off i would goo 10 or 11 psi
Old 05-22-2011, 06:23 PM   #4
pandrade
I know that the stock seting is a max of 6.5 psi, if i ramp it up to 8 or 10 you think i should invest into a good blow off valve. i am just looking for the equipment that i need befor i compleatly retune my computer ( cam gears ,shafts, greddy intercoler, aluminum pipeing, and a new turbo) right now im just covering the small bases first
Old 05-22-2011, 07:54 PM   #5
87hilux7mge
87hilux7mge's Avatar
as far as i know, a 7mgte does not require a BOV, as the KVAFM is b4 the turbo, and venting excess boost to the atmosphere would throw off A/F ratio. but im not extremely well versed with GTE's.
if it were running a MAP or MAF system, that would be another story, as those sensors are after the turbo, and can vent to the atmosphere while still receiving the correct air volume signal.
if you get a recirculating system for your BOV, it would be possible to run it, but pretty pointless, as the system is designed to work without one.
someone else more versed with turbo apps can prolly shed more light, but this is my .02.
Old 05-22-2011, 08:22 PM   #6
btwilson86
Super Moderator
btwilson86's Avatar
That's partially true. The 7MGTE runs a BPV in place of a BOV, so excess pressure is already being rerouted into the intake system (after the KVAFM). I would suggest upgrading the OEM valve though as it is likely original (20+ years old). Also, many aftermarket valves are less likely to leak boost pressure prior to opening the valve
Old 05-24-2011, 07:56 PM   #7
87hilux7mge
there ya go. similar to the supercharger systems on pontiacs etc. long as it works!
Pick My next upgrades!! Supra Saiyan MKIII Supra 14 12-20-2010 01:21 PM
lexus parts for supra upgrades TargaMKII MKII Supra 2 04-06-2006 12:57 AM
upgrades twd420 MKIII Supra 1 03-16-2006 08:56 PM
Best upgrades for 7mge KingT916 MKIII Supra 2 01-17-2006 04:12 AM
Upgrades dcrusupra MKIII Supra 3 10-07-2005 02:01 PM
