Old 05-23-2011, 10:27 PM   #1
steve0490
steve0490 is on a distinguished road
Default ecu troubles?
im having a big issue my car keeps throwing different codes, first i had code 51, then code 14 now code 10 everytime i chase the codes a new one pops up, i tried two different ecus, all my wires ar eperfect, what can be the issue maybe bad ecu's?
steve0490 is offline   Reply With Quote
Old 05-25-2011, 07:13 PM   #2
El Supracabras
El Supracabras's Avatar
There are many steps before determining the ecu is faulty. What steps were taken to clear the codes? Any diagnostics performed other than just checking and clearing the codes? If several ecu's are showing the same codes you might actually have a problem that would trigger one or more of these codes. The TSRM should have a section for the proper procedures on diagnosing and correcting the cause of each of the codes. Your going to have to read, test stuff and follow directions carefully but if everything checks out according to the manual, yes, you just might have several bad ecu's.
If ALL the wires are perfect you are very lucky. The engine wiring certainly isn't a strong point of the supra. Happy headaches!
Old 05-25-2011, 11:58 PM   #3
steve0490
yes because i have repaired what the codes were calling for and everytime i fix one thing it tells me another, also when i get one code form one ecu, ill swap the ecus (without fixing code flashed) and now after swappign ecus ill get a different code, now my car did short out the power wire, also the wiring harnes burnt up so im thinking those shorts could spiked the voltage, and now that i have replaced the harness and power wire im sitll having issures
Old 05-26-2011, 01:09 AM   #4
El Supracabras
Eww fire, that sucks. At least the car wasn't burned up. What exactly was burned? Does the car run?
Old 05-26-2011, 01:10 PM   #5
steve0490
the engine harness burned from a short so i replaced the whole harness car ran great as soon as i put it in gear it ran like shit again i got a code for tps, changed the tps car still ran like shit then itshowed code 11 then code 10 now the car wont run
Old 05-26-2011, 01:47 PM   #6
El Supracabras
You know that little bunched up set of grounds that goes under the intake manifold right by the brake booster? Check those again. Make sure they're perfect. It would be best to check the continuity of the ecu ground if you can too. If the car wont run, somethings missing. Do the basic checks (spark, fuel,etc). Was the harness an exact replacement?
oil line troubles 91turbo Non-Generation Specific Questions 2 07-26-2009 09:18 PM
engine troubles yota_head MKIII Supra 4 02-21-2007 05:58 AM
Car troubles =[ Sharaz508 MKIII Supra 9 06-20-2006 03:26 AM
Starter Troubles dcrusupra MKIII Supra 1 01-04-2006 09:15 AM
smog troubles tonster MKII Supra 2 09-24-2005 10:21 PM
