Old 05-27-2011, 10:22 PM   #11
Travis89Turbo
Travis89Turbo's Avatar
That's not pricey. That's what they cost. I do think u can get one on eBay for $10 less. But I would buy from a company.
I have one and it works great. The downside is u loose the safety of a fuel cut. It just eliminates it.
He definatly can be hitting fuel cut at 9 pounds on a 7m stock ecu. But doesn't sound right to gain that much more boost with just a downpipe thou. I would for sure check the wastegate vac line.
Very few air/fuel controllers will help your fuel cut. And they are WAY WAY more expensive then $135!
The absolute best route will always be a full standalone. You get the best of all worlds. You have a fuel cut and it will be fully adjustable. Plus all the other perks will the fuel control. But with the slight mods you have and 8lbs. Then the HKS FCD is perfect for u.
Don't get to excited with boost WITHOUT supporting mods or you will blow your engine.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 05-27-2011, 10:49 PM   #12
STR
STR is on a distinguished road
thanks. i do want to mod but i think i will take my time. 9psi will do just fine for now, just want her to not be beat by mini vans lol
STR is offline   Reply With Quote
Old 05-28-2011, 12:34 AM   #13
916MKIIIx2
916MKIIIx2 is on a distinguished road
You can definitely get a used stand-alone Air/Fuel controller with adjustable fuel cut off for 150-300 on ebay, but for you I would first find out whats making you overboost, simply putting the downpipe on shouldn't do that.
916MKIIIx2 is offline   Reply With Quote
Old 05-31-2011, 03:59 AM   #14
I disagree, fuel cut at only 9psi on a stock CT-26.... something's wrong or you're driving in VERY crap weather (HOT and DRY). 9psi is the top of the spec for the MKIII, should be able to pass that with no problem. You really shouldn't see fuel cut until at least 12psi at sea level.
A fuel controller doesn't magically allow you to up the boost. It allows you to run higher flow (via larger injectors or higher fuel pressure) and then tell the ECU that less air is actually entering the system.
A FCD just flat out lies to the ECU by telling it that once a certain threshold there is no additional air entering the system.... VERY bad idea without a fuel controller and proper tuning to ensure you're not going engine killer lean.
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
