Old 05-27-2011, 01:29 AM   #1
drod23
drod23's Avatar
drod23 is on a distinguished road
Default help!! fan clutch to electric fans
i had to replace my radiator and i wanted to convert to electric fans but i need help...
how do i wire the fans to turn on at the right temp?
do i wire it to the coolant temp switch?
anything will help..
drod23 is offline   Reply With Quote
Old 05-27-2011, 04:04 AM   #2
916MKIIIx2
916MKIIIx2 is on a distinguished road
I had twin power electric fans on my supra, after some airflow testing I found that the stock fan/shroud still moved about 3 BPU's more of cooling power. Just a thought before trying for that .25 hp you might get from the electric fan. The way I did it was I bought an aftermarket thermostat and wired the fan to relay which was wired to the thermostat to control fan on/off and speed autatically based on the cars temp. Here is a general guide that I used when doing mine. http://www.aaroncake.net/rx-7/efaninstall.htm
916MKIIIx2 is offline   Reply With Quote
Tags
clutch, conversion, electric, fan, radiator
Stock fan clutch Vs Fidanza electric fans bryanf89 MKIII Supra 8 09-10-2010 12:57 AM
Wiring Electric Fans mkiiisupra MKIII Supra 3 03-13-2009 04:58 PM
Electric fans fulljapan Non-Generation Specific Questions 4 08-14-2007 03:28 PM
-Belt driven fan +Electric Fan(s) Burn N' Up MKIII Supra 7 11-04-2005 02:37 AM
