Old 05-28-2011, 02:02 AM   #1
johnvin
johnvin is on a distinguished road
Default wont turn over :(
hey guys, i just put in a new motor got every thing hooked up and when i go to try to start it all i here is click , thats when i turn the key, it sound like the started but its brand new, it only click one time when i turn the key , NEED HELP ! thanks !
johnvin is offline   Reply With Quote
Old 05-28-2011, 03:21 AM   #2
916MKIIIx2
916MKIIIx2 is on a distinguished road
Check the neutral safety switch, also check the wiring under you dash and if an automatic push the shifter up toward park and hope you hear a click, there are other things but all those you can check in a few minutes. except maybe the switch. If the wiring under you dash has a short it will click but not crank, I had this issue where I would have to jiggle the wires under the dash until I got good contacts while keeping the key turned and it would eventually start, that problem was fixed when I finally got annoyed by it and just reconnected all the wires and heat shrank them.
916MKIIIx2 is offline   Reply With Quote
Old 05-28-2011, 07:31 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
It also is a good idea to check the battery
Old 05-28-2011, 05:45 PM   #4
916MKIIIx2
Knew I forgot something ^^
Both "Master Warning and BRAKE" light comes on while making a turn... deanja8 MKIV Supra 3 12-05-2010 03:42 PM
break lights won't turn off toyosuprastl MKIII Supra 7 09-27-2007 10:43 PM
Question About Turn Signal? and a few more small Qs! V1P3R Non-Generation Specific Questions 8 08-08-2006 04:45 AM
Key won't turn dclowe Non-Generation Specific Questions 2 05-16-2006 12:06 AM
