wont go past 2,000 rpms in any gear... HELP!
i have a 1987 toyota supra (turbo)
yesterday i started it up to just drive around town since i havnt driven it in a few days. its running fine and all for probably 3 miles and then started having this problem in any gear, or nuetral, i couldnt get the engine to rev past 2k rpms it has done this before but then fixed itself so i didnt worry about it... and now im curious of what is making this problem so i can have it fixed asap. any suggestions on what i should check out? ive never herd anything like this so i have absolutely no clue as to what to look for. Thanks! |
id check the TPS and KVAFM and possibly the CPS. those are the only few things i can think of that deal with rpm limitation at the moment..
did you check your codes.
