i have an 89 supra turbo automatic. once the car is warmed up, most anytime you let off the gas and let the engine braking slow the car down some there will be smoke coming from behind the car. if you get back on the gas some it will go away. i was wondering if anyone could tell me if its more likely my valve seals or the turbo. everything is completely stock on the car and it has 170,000 miles on it. im pretty sure the head has never been off but i cant say for the turbo. it probably hasnt eaiter but i dont know for sure. i added a quart of trans fluid in with the last 2 oil changes(4 quarts of oil and 1 quart of trans fluid) thinking that might tell me if the valve seals were bad but it hasnt helped. or the seals could be too far gone for it to have made any difference. if anyone has any ideas or things i could check to narrow it down more that would be great.
At that mileage it could be either (or both). Pull the intercooler and drain any oil present. Wash it out with kerosene and clean out the intake piping. Check in a week to see how much oil has accumulated and watch to see if the amount of smoke when coming off throttle is reduced. Valve seals usually give themselves away long before they're this bad by smoking when cold and then stopping when warm.
If you have a vacuum gauge you can test it as shown in the following link: http://www.cygnusx1.net/supra/TechTi..._readings.aspx
Valve seals usually show up the worst after sitting overnight or for an extended period then smoke upon start-up and go away afer a few seconds. Turbo bearings are usually bad about smoking when coming on and off power. Hope that helps
Smoke all around the turbo | Anthonydi | MKIII Supra | 7 | 04-24-2011 05:25 PM |
Turbo Seals, Valve seals, or lower end?!?!?!?!? | 916MKIIIx2 | MKIII Supra | 10 | 03-16-2011 04:33 PM |
First-timer here - turbo noises and smoke issues. | Kuanos | MKIII Supra | 4 | 08-22-2009 04:24 AM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
