#1 |
89 supra turbo with T61 turbo upgrade, 550cc injectors, 3 inch turbo back exhaust, Apexi SAFC, just fully rebuilt it, rod and main bearings, pistons rings, the works, i think it needs a TPS, so that could be causing the probelm im having. It has a dead miss on cylinder 6. I replaced all the plugs with the rebuild but i didnt change the plug wires and the coilpack is the same one that was on it before so either one of those could be causing it as well i guess, any other suggestions??
1989 toyota supra turbo targa top 7mgte, Five speed left hand drive. |
89 supra turbo last cylinder filled with oil?? | 89supra1990 | MKIII Supra | 4 | 01-14-2011 06:58 AM |
Master Cylinder Leak | 907mge | MKIII Supra | 1 | 04-20-2010 03:03 AM |
Clutch Master Cylinder question. 1989 Supra. | PFlanagan | MKIII Supra | 4 | 08-07-2008 08:20 PM |
Maintenance brake and clutch master cylinder fluid | IHateHacks | MKIII Supra | 1 | 04-18-2007 07:15 PM |
# 5 cylinder DEAD!??? | Caliturbo88 | Non-Generation Specific Questions | 4 | 01-31-2007 03:49 AM |
