Old 06-24-2011, 03:06 AM   #1
91 gmc
91 gmc is on a distinguished road
Default Please forgive the newb.
OK, I trying to help a friend who is somewhat forum phobic and have a few basic questions to help me get started.
First here are his mods:
1990 Toyota Supra, 7MGTE automatic.
3" exhuast
2.5" intake with Sparco intercooler
K&N Air filter
MSD ignition DIS-4
GM coil packs
We drag race with others at a track and his issue is fuel cut around 10.3 Fuel cut when racing takes the fun out of it. Anyway, 10.3 actually seems correct to me at this point. He’s waiting on a set of injs to do the Lexus mod but meantime…
I've been searching and reading and have some basic newb questions so thanks ahead of time.
As I see it the ECU controls fuel pressure. What is base FP and by what rate does FP follow boost? IOW does a pound of boost get you a pound of additional FP? If not then what? How is fuel pressure set? I see AFPR's mentioned where do they fit in?
What are the limits of (what I would call) the MAP or Manifold Absolute Pressure sensor? 2 bar, 3 bar, or? What happens (if it's even possible) if that boost level is exceeded? I know, besides a blown motor... :-)
I've searched but haven't been able to find the actual writeup on the Lexus/550 inj conversion. A link would be appreciated.
DAQ But what does the Knock Sensor rewire mod actually accomplish?
Direct links to the answers are fine. I appreciate your input. That will help me get started.
Regards,
Don
91 gmc is offline   Reply With Quote
Old 06-24-2011, 05:21 PM   #2
Sonyps307
They do a rewire on the knock sensors because the wire gets old and starts to brake. If u have a check engine light code 52 then most of the time it's the wire not the sensor.
Old 06-25-2011, 12:08 AM   #3
Nathaninwa
Nathaninwa is on a distinguished road
The ecu does not control fuel pressure directly. If its hooked up to a VSV valve is ecu controlled to run base pressure to prevent gas lock at startup and what not. And yes it is an rising rate fpr
When I ran my Lexus and 550 injectors, I was running 15psi with more than enough power for the street. I had a friend running 18psi on the same setup. Google search it more, its a really nice write up.
Nathaninwa is offline   Reply With Quote
Old 06-25-2011, 03:15 AM   #4
91 gmc
Thanks. And others, continue to post if you'd like, I'll keep searching & learning, and will probably throw out some more questions.
Old 06-25-2011, 10:44 AM   #5
mkiiisupra
lexus and 550's
http://mkiiisupra.net/bbs/showthread...ide+controller
More guides from him
http://www.mkiiisupra.net/bbs/showthread.php?t=11469
1990 Toyota Supra Turbo A/T
Newb to the site. Have a 91 Supra thats in need of repair. Introducing Myself J.Rod MKIII Supra 11 01-02-2010 07:09 AM
Newb to the site. Bought a 87 Yellow Supra Today. Introducing myself AaronCDC MKIII Supra 48 12-22-2009 11:42 PM
Supra newb needs help bad!!! Supra_Sky MKIII Supra 10 06-24-2008 10:35 PM
Hey Hey Im a NEWB with an 89 Turbo Mdunaway MKIII Supra 1 02-26-2008 02:51 AM
Newb with newb questions 1jzToyota MKIII Supra 4 11-07-2006 01:24 PM
