Old 06-24-2011, 10:46 PM   #1
rhall
rhall is on a distinguished road
Question question
i'm interesting in buying a xtr stage 3 clutch kit or an xtd stage 3 clutch kit... which clutch is a better set up for a 1988 toyota turbo supra?
rhall is offline   Reply With Quote
Old 06-27-2011, 09:06 PM   #2
87hilux7mge
87hilux7mge's Avatar
chebay clutches are mostly crap. ive had better luck with some F1 clutches, but your probably better off with a stock replacement or a good aftermarket unit like spec, clutchmasters (NOT Eclutchmasters) or ram etc...
Old 06-27-2011, 10:46 PM   #3
TimeLess87
TimeLess87's Avatar
TimeLess87 is on a distinguished road
I have an RPS stage 3 in my supra. Couldn't be happier with it, and my car isn't stock by a long shot. I believe I paid in the neighborhood of $550 to $600 for it. Plus, I didn't notice any change in pedal feel.
87 Turbo, 5-speed Supra Hard Top
GM mas airflow sensor translator, 550cc RC injectors. Blitz NUR spec exhaust, Custom 3" down pipe w/ QTP E cut out, Short throw shifter. Spearco FMIC, custom upper and lower charge pipe, and so much more
TimeLess87 is offline   Reply With Quote
Old 06-28-2011, 01:35 AM   #4
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
We really wouldn't be able to recommend a clutch for you because we really have no idea what you have done to your car....If you're running stock boost and a couple bolt on's you would better off with a stage 2 2100lb-2600lb single disk or 6 puck clutch depending on what you would be comfortable driving with on your supra.....Just stay away from cheap off brand clutch's.
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
oil leak question ftwmotorsports MKIII Supra 9 02-12-2010 03:53 PM
