Old 06-29-2011, 02:04 AM   #1
CobraDBlade
CobraDBlade is on a distinguished road
Default Brake issues
I have a stock 1990 Supra Turbo with a brake issue that is driving me insane. The brakes work fine when the car has been first started up, but after about 20-30 minutes of driving, the pedal goes almost completely to the floor before the brakes apply. The car had a brake fluid leak at the right front caliper and between the master cylinder and brake booster when I bought the car a year ago. MC, caliper, and booster have all been replaced (booster was almost half way full of fluid!). I made sure to bleed the brakes each time a line had to be removed, but am scheduling a power bleed/ brake fluid flush just to be sure. What's really weird though is that when the pedal starts dropping, if you park the car, pull the booster vacuum line (or otherwise vent the vacuum out of the booster) then the brakes will work fine for another 20-30 minutes. Could the booster check valve be the issue? If not, what could? Any help at all will be much appreciated.
CobraDBlade is offline   Reply With Quote
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
