Old 07-06-2011, 05:13 PM   #1
johnvin
johnvin is on a distinguished road
Default wiring
hey guys, im in the process of getting my new motor running, im having a hard time with the wiring part. i have 2 wires on the intake manifold side that i can not figure out what they belong to, i tested them and one has power running to it and the other one is a ground, when i turn my key over to on not to start it, i hear a buzzing noise comming from one of the relays on the other side of the car, and then when i take the on that has power running too it the buzzing stops, any wire digrames would really help me. thanks guys ! the car 1988 7mge manual
johnvin is offline   Reply With Quote
Old 07-07-2011, 12:20 AM   #2
IKneX
IKneX is on a distinguished road
What colours are the wires? I have a diagram, ill see if I can find you the one your looking for.
IKneX is offline   Reply With Quote
Old 07-08-2011, 01:56 AM   #3
johnvin
the wires are on the intake manifold side, there located down by the starter,
Old 07-08-2011, 02:35 AM   #4
IKneX
what colours are the wires?
Old 07-08-2011, 05:39 AM   #5
johnvin
one of them are white with black stripe, and the other it brown , it looks like they would slip on a bolt and then tighten with a nut on top, there the the wires that go on top of the started for your power. but i know its not that because my started is already hooked up and working, both have double wires ran too like the copper post or connector what ever its called. thank you so much for your time
Old 07-08-2011, 08:39 PM   #6
johnvin
do any of you guys have a wire diagram? that would really help!
Old 07-09-2011, 12:37 AM   #7
They're grounds. The eyelet fits on a stud on the lower part of the intake manifold. White with black stripe is a standard ground. The brown line is the ECU's E1 ground.
Old 07-09-2011, 01:16 AM   #8
johnvin
so it dont matter where i bolt them on too as long as they have a good ground ? do they need to be together ? or separate
Old 07-09-2011, 04:58 AM   #9
IKneX
He is right, I looked at my car this morning, I have 2 white wires with black strips, and 2 brown wires right above the starter. all 4 wires are hooked into one ring whitch is grounded.
Engine wiring loom? redsupra MKIV Supra 4 12-19-2011 01:05 AM
Power Folding Mirror Install nfa_automotive MKIII Supra 2 05-25-2010 01:13 AM
HKS VPC wiring diagrams cat007 MKIII Supra 0 11-07-2005 09:28 AM
