Old 07-09-2011, 03:51 AM   #1
87hilux7mge
87hilux7mge's Avatar
Default piston/deck clearance: how much is too much?
so, im wondering, would i be able to get away with .030" above deck? when i had my n/a block done, i ended up with a total of .024" above deck, i believe stock is .020?
i could always get a 2.0mm mhg to avoid piston to valve contact, im just worried about top ring and ringland.
if anyones got an opinion about this, lemme know, itll help with the easy stroker setup.
Old 07-12-2011, 09:17 AM   #2
kamikazemkiii
kamikazemkiii is on a distinguished road
I dont believe you'll have any problems, just use a thicker headgasket.
kamikazemkiii is offline   Reply With Quote
Old 07-13-2011, 06:23 AM   #3
87hilux7mge
thats my thought, but im also concerned with squish area. i think itll be ok.
Old 07-13-2011, 06:25 AM   #4
two-step-n
your fine just run a 2mm hks stoper
Old 07-13-2011, 06:31 AM   #5
87hilux7mge
aight. this is for the stroker, they are basically gonna be custom 1.181" compression height pistons for a b-series honda with machined wrist pin sizes. decided the 1.52:1 rod/stroke ratio was too little, so these will allow keeping the stock rods. any more info if anyone wants to pipe in?
Old 07-13-2011, 06:54 AM   #6
kamikazemkiii
Honda pistons dont belong in a supra...
Old 07-13-2011, 07:28 AM   #7
87hilux7mge
yea i know, but they are the ones with the right compression height, and since they are forged and would be modified. sooooo...i say they are serving the higher toyota purpose.
7M-GTE Valve Clearance ???? professorbob MKIII Supra 3 05-13-2011 06:25 PM
Intake Valves Clearance Adjustment question donkey MKIII Supra 1 09-14-2009 02:45 AM
Valve Clearance adjustment gorillaguy8 MKIII Supra 5 09-03-2009 09:17 PM
TB clearance? redmaro MKIII Supra 1 02-14-2007 12:18 AM
Valve Clearance BRGNDY88 MKIII Supra 5 10-04-2005 03:56 AM
