Old 07-12-2011, 12:00 AM   #1
rodney120985
rodney120985 is on a distinguished road
Default Idle Oil Pressure
Ok i did a search for this question and i didnt find anything, might have looked for the wrong thing not sure. Ok i have a question about my oil pressure i have a N/A motor and and when i sit with the car idling it slowly drops from 40psi to below 10 i think whatever is the lowest on the gauge. Dont know if this is a problem or not. I was kinda think that my oil pump was goin out so i am wantin to see if that is something i am goin to have to tear into motor for or if this is a normal thing
rodney120985 is offline   Reply With Quote
Old 07-12-2011, 02:27 AM   #2
IKneX
IKneX is on a distinguished road
Oil Pressure Specs:
At Idile: More then 4.3 psi
At 3,000 RPM: 36-71 psi
engine at normal operation temperature
Source, All Data
So I am going to assume that is normal, because engines usually rev up a little bit when started up. I guess as long as your above 4.3 at idile your ok.
IKneX is offline   Reply With Quote
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
Oil Pressure? supraguy MKIII Supra 3 09-16-2009 08:35 PM
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
