#1 |
plz help identify and explain a little what i have
#2 |
sure looks like a 7mgte.it is also missing a piece of the timing cover, and middle of your strut brace. you also have an aluminum radiator, and some sort of bov. you should also look into an air filter.
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#3 |
srry my mistake i have a air filter and the timing cover? cant you keep that off to show the gears?
#4 |
#5 |
if possible i would like a site where i can compare mine to a stock 7m or just someone elses
#6 |
try searching this site or google.
#7 |
i see aftermarket I/C piping, aftermarket FPR, Radiator, and thats about it for differences.
87 toyota 4x4 single cab short box pickup, 7MGZE. |
#8 |
ok and i also have a vein pressure converter and a safc? i think thats what it is i have no idea what they do:/
#9 |
Supra Forum Moderator
http://www.ma70.com/bishop92t/techtips/index.html
i dig the orange valve covers. im going to paint my oil pan construction orange whenever I get around to redoing it.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#10 | |
![]() Quote:
You goal is to get him running as smoothly as possible, smooth is good rough is bad.
1986 Mk III MA70 7MGE Targa Top 5 Speed Stock Exhaust ![]() |
cold starting problems | Cjanik | MKIII Supra | 9 | 08-02-2008 06:50 PM |
Starting isssues and spark knock Q's | spudz29212MKIII | MKIII Supra | 65 | 05-30-2008 06:44 PM |
starting motor | Dom | MKIV Supra | 3 | 04-05-2007 01:57 PM |
1986.5 Starting Problem | supraman121 | MKIII Supra | 4 | 09-03-2006 03:51 AM |
engine noise car dies after starting | tex1116 | MKIII Supra | 7 | 11-18-2005 06:47 PM |
