Old 07-13-2011, 07:11 PM   #1
IKneX
IKneX is on a distinguished road
Default MAF Replacement
So my CEL now comes with code 31, MAF. Can I buy the lexus sc400 maf and bolt it on without modding anything else? I found one on ebay for a pretty good price
IKneX is offline   Reply With Quote
Old 07-14-2011, 12:17 AM   #2
El Supracabras
El Supracabras's Avatar
http://www.suprasonic.org/lexusriemer/lexusnotes.html = the point of this.
Short is answer yes you can and no you shouldn't. By the way you got the letters mixed up, its AFM not MAF.
Old 07-14-2011, 12:23 AM   #3
IKneX
Oh yeah, I dunno where I came up with MAF im trying to keep my motor as stock as I can, I just want everything to run 100% smooth, ill stick with the 7m AFM.
Old 07-14-2011, 01:31 AM   #4
Green7mgte
Supra Forum Moderator
you can hook up the black box. just not the honey comb w/o any ill effects.
code 31.. before you spend any money do yourself a favor and run an ohm meter from your pins and check the wires.. if you have a bad wire, replace it. Otherwise spending w/e money you did on your KVAFM is money wasted.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 07-14-2011, 03:05 AM   #5
IKneX
K, ill check that, im assuming is in the TSRM?
Old 07-14-2011, 03:48 AM   #6
El Supracabras
If your AFM fails the tests and that Lexus AFM is cheap, buy it, use the sensor and sell the housing. The sensor is the same as yours the housings are different. Just put the sensor in your 7M housing. Be sure to closely inspect the connector and wires while testing the sensor.
Old 07-14-2011, 03:57 AM   #7
Green7mgte
yes the sensor or "black box" is the same. The housing "honeycomb" from the lex is for a v8 and allows 15% more air to enter the engine. Bad news if your not pushing more fuel.. results in whats called "running lean" and that will destroy your engine.
Supra FAQ
Supra MKIII FAQ
Old 07-14-2011, 01:05 PM   #8
IKneX
Oh I didnt know that, Thats what I was gonno do anyway because the ebay one was JUST the sensor not the houseing. So as long as I keep my 7m houseing I can use the lexus one?
Steering Wheel Replacement OdysseusOnWheels MKIII Supra 3 04-21-2011 09:05 PM
1991 Non-Turbo Supra - Power Antennae Replacement Options unkymurch Non-Generation Specific Questions 2 04-29-2007 06:35 PM
Front Signal Light Assembly replacement Saturn MKIII Supra 1 05-19-2006 11:12 AM
